Failure Warnings
08.05.2020 20:28 # 1
denizzined
Hi;
First of all I'm new here, thanks for your support already.
My vehicle, 2003 model 307 xt automatic gear 172000 km, the problem I have encountered for 2 times today, when I stop the vehicle, when I turn off the ignition, I get the messages written below, I request you to help.
When the ignition is switched off, it writes these warnings respectively and continues continuously, errors are turned on when the ignition is switched on and off.
oil pressure insufficient
braking system fault
automatic gear fault
abs fault, no problem in normal driving, brakes are perfectly normal
denizzined 2017-07-19 23:11:47
08.05.2020 20:28 # 2
Oktkor
Your brake fluid is low or nearly empty.
I think 3 errors are related to the oil level. the other gear is usually said of the solenoids in the gearbox.
08.05.2020 20:28 # 3
denizzined
thanks
08.05.2020 20:28 # 4
uzunca961
[QUOTE = denizzined] thanks [/ QUOTE]
There is a possibility that it is related to the battery. To make a battery measurement in a simple place
08.05.2020 20:28 # 5
denizzined
I looked at the hydraulic oil at a normal level
08.05.2020 20:28 # 6
uzunca961
[QUOTE = denizzined] I looked at hydraulic oil at normal level [/ QUOTE]
When you first get into the car, it gives me my mistakes if it doesn't give you any mistakes.
If he is doing it while riding, there is a possibility that it is from the battery.
But if you say it doesn't disappear, you may need to take it somewhere in your brain.
08.05.2020 20:28 # 7
denizzined
Data only when the ignition is turned off
08.05.2020 20:28 # 8
uzunca961
[QUOTE = denizzined] It is only given when the ignition is turned off. [/ QUOTE]
If the battery last changed when it was old, it would be deemed new
Nevertheless, nobody gets money to control the battery anyway. But get a proper place
08.05.2020 20:28 # 9
Oktkor
The battery is already charged. He should have given these warnings at least on the first run.
08.05.2020 20:28 # 10
KILIC
Did you check the vehicle's engine oil, when was the oil filter last changed? If the oil filter has not changed for a long time, I recommend you to change it. Other malfunction codes may be temporary, and there may be dirt on the abs. If it deletes them again, then it is checked. I don't think it's a big problem. Problem with your oil filter
08.05.2020 20:28 # 11
denizzined
Hi;
I changed the oil change and filter 15 days ago, I have made 500 km after the change, it does not give any warning when driving, there is no problem in the gear changes, manual manual, there is no knock in the gear shift, today, a master says that if the adjustment of the selonoid valves is adjusted, the oil pressure is low, he says, I'm not sure I will get an appointment from the service and have it checked in the week, I hope there is no problem as you said.
08.05.2020 20:28 # 12
KILIC
[QUOTE = denizzined] Hi;
So it started to give errors after the oil change. I think there is a problem with the oil filter as there is a lot of issues related to it. I think 10-15 TL for a low cost piece, I think try to change it first. If there is no problem with gear shifts or knocks, I think you should never play with a cellophane.
SWORD 2017-07-21 09:42:46
08.05.2020 20:28 # 13
denizzined
I looked at the oil change card, I made this error on 28 June, I have been getting this error for 2 days, there is no problem with the gear shifts, I looked at the oil stick in the morning, I take the normal gear N in the oil between 2 notches, pull the hand brake, turn the ignition off and get the warning messages start
08.05.2020 20:28 # 14
KILIC
[QUOTE = denizzined] I looked at the change of oil on the card on 28 June I have been getting this error for 2 days. QUOTE]
Let's take a look at the subject that the solution has been reached, maybe it may be the same problem.
08.05.2020 20:28 # 15
denizzined
So other warnings can cause,
08.05.2020 20:28 # 16
KILIC
As I said in the other warnings, there is dirt dust, dust and dust. If it gives them again, then it is checked.
08.05.2020 20:28 # 17
denizzined
Can't we clear the faults ourselves
08.05.2020 20:28 # 18
whisky
If you have an OBDII device, you can delete it yourself.
08.05.2020 20:28 # 19
KILIC
[QUOTE = denizzined] Can't we delete the faults ourselves [/ QUOTE]
In n11, 20-25 rubles of obd devices are sold. Bluetooth with the program you download to your mobile phone
you can actually connect and delete.
SWORD 2017-07-21 14:02:54
08.05.2020 20:28 # 20
uzunca961
[QUOTE = SWORD] [QUOTE = denizzined] Can't we delete faults ourselves [/ QUOTE]
Is it possible to change the vehicle configuration with those 20-25 TL instruments?
Page : / 2
