Failure not found in 307 konya
08.05.2020 17:33 # 1
levent291
1.4 2005 307 I have the blue light on the brake when it turns the steering wheel to the left or right, while it is idle while waiting, the oil lamp lights up and gives a sound signal. Oil pump changed - oil sensor changed - oil changed - filters changed etc. The vehicle is hard to switch to LPG on the first run with LPG. Occasionally, the trip computer resets. Gas gauge is inconsistent. I am tired of giving money to repairers who did trials and replaced parts that could not find the fault. Shameless guys are both unable to make money. An electronics worker looked at his brain and said 750 TL. You will make a lot of money, only an electrical problem engine, friend. Engine oil is everything, normal but this gives malfunction. There is gas, light is on, I buy 10 TL, this time is full. IF YOU HAVE LIVING THIS, PLEASE WRITE.
08.05.2020 17:33 # 2
It seemed to me an electrical problem. In the first place, I go to a battery and measure your alternator.
08.05.2020 17:33 # 3
fexzi
alternatives that come to my mind If there is a problem with -lpg, 90% was due to the problem in assembly.
08.05.2020 17:33 # 4
terzuu
hi,
have the battery checked. If it is normal, it may be a charging motor or main fuse box.
best of all, you need to connect it to the computer and see the error. / DIV>
terzuu 2013-04-28 10:52:13
