Fail to shift into reverse
08.05.2020 20:39 # 1
losangarass
the pressure ax is in good condition, we have shown that the gears are clicks, but in the meantime, it does not fit well once in a while. losangarass 2017-11-30 23:25:15
08.05.2020 20:39 # 2
Oktkor
Normal.
08.05.2020 20:39 # 3
losangarass
[QUOTE = Oktk] Usual. [/ QUOTE] thank you president or I am afraid that my transmission will go down
08.05.2020 20:39 # 4
aykutbayram1996
What is normal is that my 206 is always on the wheel so there is no trouble with gear connections.
08.05.2020 20:39 # 5
ggitaristt
Sometimes I can not put it in reverse at once. Try to move the car a little bit instead of removing it.
Probably the reverse gear ring is a little peeled. It is necessary to manage, no expense.
But have the transmission oil checked, if there is a shortage, there will be a problem.
08.05.2020 20:39 # 6
vpro
Sometimes it doesn't pass right away. Plug it back into very light throttle and gently pull the foot out of the clutch and the car vibrates. vPro 2017-12-01 08:22:18
08.05.2020 20:39 # 7
maximusti
The problem is with the gear gear, the times when my gear shifts out and pulls it back again when it is not in my vehicle.
08.05.2020 20:39 # 8
Karaelmas
My vehicle had the same problem in 2009 model 207 160 thousand half automatic, first they said the press brake, we did not improve, then they did not reduce the transmission, the result was not with the pad, 3,500 pounds in the vehicle right now, there is no bicycles, only a little fuck in the back while using it in the back, and a little bit of it will look again. Black Diamond 2018-01-01 10:47:52
