EXTREME WHITE SMOKE AND EVAPORATION
08.05.2020 17:11 # 1
SK108
Hello,
1998 MODEL AUTOMATIC 106 When I run the car in the car with LPG 106 XS LPG, especially in the morning (in cold weather), WHITE SMOKE AND STEAMING occurs in the exhaust. As I hold my hand in that steam, there is a very slight humidity. working on gasoline, after working 3-5 minutes passes to LPG. I can say that this white smoke and steam event continues for 6-7 minutes. What is the reason of this ? Why do you think it might be? Anyone experiencing this kind of event?
& nbsp;
Thank you.
08.05.2020 17:11 # 2
Serkan
Hodja, you mentioned that the water decreased in your other subject, how is the temperature of the vehicle?
08.05.2020 17:11 # 3
SK108
Well, the movement seems to be normal in the middle of the line. I know that the heat problem is common in the 106s.
& nbsp;
Thank you.
08.05.2020 17:11 # 4
Serkan
Sir, in the mornings, white smoke for a short time is normal, but it takes 12-13 minutes according to your message, and it diminishes in the water.
08.05.2020 17:11 # 5
outlaw
In the summer, you won't have this complaint, there are 106 in me, and the same thing is happening with me, but it is not a distressing situation. hot is normal. outlaw 2012-12-07 17:51:48
08.05.2020 17:11 # 6
Serkan
[QUOTE = outlaw] In the summer you won't have this complaint, there are 106 in me, and the same thing is happening with me, but it is not a problem.
The air is cold, the air is hot. It is normal. [/ QUOTE]
Sir, the amount and duration of the smoke is important. is normal if water does not subside
08.05.2020 17:11 # 7
SK108
okay guys thank you for your help.
& nbsp;
I write the developments if necessary.
& nbsp;
Good evening.
