EXTREME VISION IN THE VEHICLE
08.05.2020 19:36 # 1
ARDADOGAN
Friends 2007 model 307 is in the car, there is always a mist, I don't even hurt the windows.
08.05.2020 19:36 # 2
talip206
Air orientations can be troublesome. Give the air to the windows and manually control.
Also check the carpets under the mats if it is wet, it is getting water from somewhere and it steams.
08.05.2020 19:36 # 3
sanctuary35
I always have to turn on the air conditioner.
08.05.2020 19:36 # 4
samet206
Now, there is a situation like this, in general, it is necessary to either open a heater or open a glass, and if the two are made together, the misting increases even more. Especially in rainy weather, there is excessive misting. It is not necessary to give the level only to the windows. I need to check it, I wonder if it has a problem, everything is working well. I know that even using a carpet mat in the winter season increases the formation of mists inside the car.
08.05.2020 19:36 # 5
misafirkadir
I significantly reduced fogging with the anti-fog spray.
Sold in Migros CARPEX glass name
08.05.2020 19:36 # 6
Cmon
The recycling or circular key to the left of the A / C key should not be active. If it is active, since your ventilation system will reuse the air inside, moisture will increase and mist will occur in all glasses.
08.05.2020 19:36 # 7
[QUOTE = Cmon]
+1 Clap
08.05.2020 19:36 # 8
yawruaslan
just as it does not circulate the air inside the vehicle, if air gets in from the outside, this does not occur today.
08.05.2020 19:36 # 9
Sertan
If you want the same problem in me, sprays are sold to prevent mist. You can squeeze it in the cloth and see the benefit of wipe glass, brother.
08.05.2020 19:36 # 10
Sevket307
First of all, hello everyone, the key next to the Ac knob should not be open, the second one should be on the calolifer honeycomb. It sticks and makes a mist, so there is a slight odor in the vehicle.
08.05.2020 19:36 # 11
hsoycercel
That's why the radiator radiator hole. The radiator will change and I suffered from it.
08.05.2020 19:36 # 12
pusutr
It is normal that condensation forms due to the difference of temperature in the outside and inside. As the temperature difference increases, the mist density increases.
New generation vehicles have an anti-fog button. This button is the air conditioner button we know.
If you have an air conditioner when the fog is intense, operating it will dissolve all the mist in a short time.
If you do not have any other problems, do not tamper with your vehicle for this reason only.
08.05.2020 19:36 # 13
emrahyilmaz84
If your pollen filter is clogged, it can dissolve the window mist too late.
08.05.2020 19:36 # 14
Dzking
Condensation occurs when the inside of the car is damp or when the pollen filter is clogged. Instead of defrosting the glass, leave it in the foot position and try ac. Good forms.
08.05.2020 19:36 # 15
ARDADOGAN
I know it is not about it
08.05.2020 19:36 # 16
ARDADOGAN
I have no choice yet :)
08.05.2020 19:36 # 17
ARDADOGAN
Thank you I haven't tried it ...
