External wiring assistance for 206 fog light |
| 08.05.2020 20:00 | # 2 |
Friends with the idea of not having it. |
| 08.05.2020 20:00 | # 3 |
sonerkyl |
In my opinion, there is no problem, electricians usually take the line from the back fog, but I think it is not good. If the system draws a new line like the diagram you have given, it will not be a problem. https://tr.aliexpress.com/item/led-car-switch-light-truck-light-toggle-switch-5pin-waterproof-spot-driving-led-light-bar-tray/32608302515.html?spm= 2114.010208.3.1.vtlot a & ws_ab_test = searchweb0_0, searchweb201602_2_10065_10068_10069_10084_10083_10017_10080_10082_10081_10060_10061_10062_10056_10055_10054_10059_10078_10079_10073_10070_421_420_10052_10053_10050_10051, searchweb201603_4 & btsid = 796fa292-2f5f-4614-84f2-3faba83762e9
| 08.05.2020 20:00 | # 4 |
My brother is in the vehicle. They made a connection with the back fog. My father made a back with him because of the heat, I will have a separate button.
| 08.05.2020 20:00 | # 5 |
Thank you very much for the answer, I wondered if there was an electrical error in the diagram, I have information, but auto electricity scares me, maybe there is an error or something to be added. I like the button. |
| 08.05.2020 20:00 | # 6 |
I do not think that a separate button will cause problems in the inspection, even if the front fog lights are not completely lit up, as far as I know, most officers can not burn the fog, write a slight defect. There are things that should be but there are those who use it as such. I prefer a separate button. I try to set up a glass installation as shown. I write positive or negative here. |
| 08.05.2020 20:00 | # 7 |
Guys, I prepared the electrical installation, there is a situation that is stuck on my head. When I pull the cable from the battery directly to the leg number 30 of this relay, it will still be active when the contact is closed, so when the button we put together closes, will the relay draw energy? How can we do this to prevent possible open forgotten when we pull the cable from a place where the electricity comes from when the contact on leg 30 is opened. |
| 08.05.2020 20:00 | # 8 |
obviously you will not forget to solve it, you will find that you will spend much money on the liner to get it out. When the button in between is closed, it cannot draw energy or complete the line.
| 08.05.2020 20:00 | # 9 |
Thanks to my understanding, even if the 30 number is directly connected to the battery, this is when I want to ask, as long as the button on the trigger tip is not closed, the energy will not be lost. There are some old topics, but either the visuals have been lost or the articles have been lost. I can not understand. Thank you. |
