External Temperature Indicator Has Started To Show Wrong
08.05.2020 15:15 # 1
cagdasi
Hello, I searched the forum but opened a new topic because I could not find any results. The external heat shield on my vehicle has stopped working correctly for a few days.
Namely; When the outside temperature is around +5 degrees, the value on the screen on my vehicle can be like 0 or -1 and even lower. I tried whether the sensor is working with my hand or other heat sources, it shows the changes.
Is there anything happened to this problem before, can something like this happen because the water, mud, etc. has escaped to the sensor?
My vehicle is 2004 307 XT Gasoline / LPG, thanks in advance.
08.05.2020 15:15 # 2
metin
it may be contaminated yes.
I saw a similar topic in the forum, they were talking there.
I know that when you fold the mirror fully, you can remove it and remove it, and if there is a friend who knows it, it will inform you better.
08.05.2020 15:15 # 3
Probably in the last bits of his shoulder. If you want, you can go to a cleaning path. Maybe there is oxidation or fluid contact on your legs and this is causing extra resistance. For Sensor I once put the sema into the forum. You can find Aratip. Koliva 2011-04-11 12:23:48
08.05.2020 15:15 # 4
metin
[QUOTE = koliva] Probably in the last parts of his shoulder. If you want, you can go to a cleaning path. Maybe there is oxidation or fluid contact on your legs and this is causing extra resistance. For Sensor I once put the sema into the forum. You can find Aratip. [/ QUOTE]
When I was thinking how to explain it to me, you came to my mind, now that it sticks the scheme (:
08.05.2020 15:15 # 5
cagdasi
I looked at your messages but I couldn't find it, if you would like to add it again, would you add the scheme you mentioned.
Does this sensor have a new one, or is it a problem if it is this way?
08.05.2020 15:15 # 6
[QUOTE = text]
So let me put a whirlwind Göz Kırpma
08.05.2020 15:15 # 7
[QUOTE = cagda of]
It does not cause any problems to work in this way. This sensor has no contribution to the operation of the engine. Only if it shows a minus, the flashing soner on the screen is so. I think it's not expensive. There is a sponsor in the forum, if you write in its title, it will tell you the price.
08.05.2020 15:15 # 8
The sky above seems to be of no use to you because it was an answer to tell where the sensor is.
To remove the sensor, as Metin said, you completely break the mirror (metaphorically, so you tend to tilt it). Kahkaha ). In this way, you can open the clip inside by inserting a long screwdriver through the gap. Cut the wires and remove the sensor. When you install the new one, you solder it in place. Otherwise, you will have to defrag the new cable again.
08.05.2020 15:15 # 9
cagdasi
[QUOTE = koliva] The sky above seems to be of no use to you because it was an answer to explain where that sensor is.
I do not know your name, do not look at my fault, Mr. Koliva; I do not know correctly, I do not need to remove the door trim to remove this sensor, that is, I just need to disassemble the mirror.
I will follow up for a few days, then if I can find the sensor, I will try to remove and renew it, but of course it is a matter of finding the sensor.
08.05.2020 15:15 # 10
metin
[QUOTE = cagdasi] [QUOTE = koliva] The sky above seems to be of no use to you because it was an answer to explain where that sensor is.
you don't need to remove the mirror either.
fold the mirror fully but don't break it. After folding, you have to remove the clips that you can remove with the help of a screwdriver.
08.05.2020 15:15 # 11
[QUOTE = cagda of]
It should be as Metin said. You can also test if there is an ohmmeter when you remove the sensor. He needs to read resistance.
08.05.2020 15:15 # 12
Serhun
If you find a PTC Thermistor it will work, but now I can't remember your full information. Generally, water enters the mirror from there and oxidation occurs in its connector, it is not a circuit element that can deteriorate under normal conditions.
08.05.2020 15:15 # 13
cagdasi
The problem with the temperature sensor continues, I think there is no other solution to change.
Does this sensor malfunction create a problem in the operation of the digital air conditioner, do you know about it?
08.05.2020 15:15 # 14
metin
When I turn on the digital air conditioner, when I press auto, I know that he is adjusting his own temperature according to the temperature of the interior.
08.05.2020 15:15 # 15
[QUOTE = cagdasi] The problem with the temperature sensor continues, I think there is no other way to change.
Does this sensor malfunction create a problem in the operation of the digital air conditioner, do you know about it? [/ QUOTE]
I cannot leave the sensor inside the mirror connected to the air conditioner. But in my automatic air conditioner in my car, there is a separate external temperature sensor. he is standing in the mouth of the air intake.
How I can not leave in the 307s. we need to find and look at the air conditioning system diagram
08.05.2020 15:15 # 16
metin
cem brother said schema, and I came to mind koliva (:
puts the scheme soon Alkış
08.05.2020 15:15 # 17
cagdasi
I run the air conditioner in the morning for trial purposes, a compressor comes into play, it turns out (idle) and cold air did not come, it came to my mind that it might be due to low external temperature, I ran it at 20 degrees.
08.05.2020 15:15 # 18
volkan_uysal
I also have the same vehicle, it usually shows 3-4 degrees low in mine. But this has nothing to do with automatic air conditioning, at least not in my car. Let's say its content in cold weather is 24 degrees in auto mode. If you leave the door slightly open, the fan will start at full speed. Gülme
I know that medium illumination measures the heat inside from there.
Whether you show low, it does not matter to me ....
volkan_uysal 2011-04-21 12:58:22
08.05.2020 15:15 # 19
Serhun
In a vehicle without digital air conditioner, the electric heater was also activated when we started the heating (without the vehicle running) because the outside temperature indicator showed wrong. A similar system can plot.
08.05.2020 15:15 # 20
hasansinayan
I said I will be hooking the subject, but I am not going to hurt another subject. How can I clean the sensor without inserting the sensor?
Page : / 2
