Experienced friends about LPG
08.05.2020 15:32 # 1
shadow_okan
SA FRIENDS MY VEHICLE 307 XSI 2.00 ENGINE ON MILANO BRAND SEQUENCE LPG VAAR.
I WILL BE WATER IF THE QUESTION. SEQUENTIAL LPGS START ON GAS AND GAS GAS.
BUT I GET 50 TL GAS I GET 50 TL GASOLINE.
SO GAS GAS MIXING OF GAS, I NEED TO BURN OR HAVE A SOLUTION FOR THIS. 50 TL LIKE GAS A LONG TIME AFTER TO GO TO THE LONG TIME.
IF YOU HAVE EXPERIENCE INFORMATION, PLEASE HELP.
I HAVE MADE THE SERVICE IN IZMIR, WHEN I WAS NOT IN THE WHERE I HAVE MADE IT.
I HAPPENS EVERYONE, I AM HAPPY TO BE HERE
08.05.2020 15:32 # 2
This is one of the peugeot's chronic malfunctions. Don't worry, I have the same problem as a 206 user, but nothing to be afraid of.
08.05.2020 15:32 # 3
Such questions come from every Peugeot friend. The reason for the lowering of the petrol pointer is not connected to the fuel gauge in French vehicles. The vehicle automatically lowers the gasoline level according to the km traveled. So they made an interesting system. Of course, there is a way to overcome this problem. You can see many solutions to this problem by searching the forum. However, the most definitive solution is a module called PSA. With this module, you can see that the gas gauge shows the real value when you turn off the ignition and turn it back on when you have finished your journey.
Do not worry, your vehicle does not consume gas. Our showers just like spending ...
08.05.2020 15:32 # 4
hunterakon
Buy 25 pounds of gasoline once a week, at least it gets old again.You need to have a psa module installed for the solution.
so it saves 25 pounds of gasoline once a week or 2 weeks (at first it is better if your tank is full: D varies depending on the usage.
08.05.2020 15:32 # 5
boraa
Attaching lpg to sister pugs is a chronic failure once in itself. Gülme Ninety percent of these vehicles to our LPG uymuyor.takıl car after a certain period of a thousand kinds of range full and error can not find yere.sonr malfunction then you go to come back from the service LPG if the veriyor.o and their answers clear: `` chronic failure of these tools, this ``. or the master you have had is not good, dear, it is malfunctioning. I have seriously investigated the lpg event. So I gave up at the last minute. Some of my friends had it dismantled. Mine is just an experience. I hope your problem will be solved ......
08.05.2020 15:32 # 6
I use it with 25,000 km dir lpg. There is no problem..
08.05.2020 15:32 # 7
emrnl
[QUOTE = erhanomer] Such questions come from every Peugeot friend. The reason for the lowering of the petrol pointer is not connected to the fuel gauge in French vehicles. The vehicle automatically lowers the gasoline level according to the km traveled. So they made an interesting system. Of course, there is a way to overcome this problem. You can see many solutions to this problem by searching the forum. However, the most definitive solution is a module called PSA. With this module, you can see that the gas gauge shows the real value when you turn off the ignition and turn it back on when you have finished your journey.
+1
08.05.2020 15:32 # 8
trtolgi
The vehicle has been lpgli for 35000 kilometers. The system of preventing air pollution only gives warning.
08.05.2020 15:32 # 9
[QUOTE = boraa] Having lpg on sister pugs is a chronic failure once Gülme Ninety percent of these vehicles to our LPG uymuyor.takıl car after a certain period of a thousand kinds of range full and error can not find yere.sonr malfunction then you go to come back from the service LPG if the veriyor.o and their answers clear: `` chronic failure of these tools, this ``. or the master you have had is not good, dear, it is malfunctioning. I have seriously investigated the lpg event. So I gave up at the last minute. Some of my friends had it dismantled. Mine is just an experience. I hope your problem will be solved ......
I have 2000 model Peugeot 206. My car is 1.6 and I have Atiker brand LPG in my car. I measured last month, it burns 23 cents a kilometer in the city. I AM VERY PLEASED.
mustiii 2011-06-06 00:54:40
08.05.2020 15:32 # 10
se®k@n
[QUOTE = mustiii]
I guess my cries if it burns so much .. Sırıtma
By the way, when it comes to the problem of gasoline needle; I had a lot of research and asked while I was wearing LPG .. I think this problem is happening in 2003 model and above .. It can be solved with a module but ..
08.05.2020 15:32 # 11
ose
you can handle this at zero cost. It was written very much. link below. not zero cost actually 2tl or 3tl
Sırıtma
08.05.2020 15:32 # 12
Friends did not give the necessary answer :))
The fact that the gas gauge is dropped is not a malfunction, but a situation related to the structure of the vehicle ...
08.05.2020 15:32 # 13
shadow_okan
Best of all, let me get 25 TL of gas.I put 10 liters of gas in the bag.We will put it in the knife where it is now.
50 TL lpg 25 TL gasoline. Let's see how many km will go.
Because whenever I buy LPG, if I take 50 TL of gas, I will get 100 TL of plain gas. My head will be comfortable.
08.05.2020 15:32 # 14
[QUOTE = se®k @ n] [QUOTE = mustiii]
How much fuel does your vehicle consume?
Is your vehicle 16 valve, mine 8 valve from it?
08.05.2020 15:32 # 15
metin
[QUOTE = shadow_okan] SA FRIENDS MY VEHICLE 307 XSİ 2.00 ENGINE ON MILLAN BRAND SEQUENCE LPG VAAR.
It would be better if you share the features of the vehicle in the signature section as well as the lpg brand model.
08.05.2020 15:32 # 16
metin
[QUOTE = facemelowe] is one of peugeot's chronic malfunction. Don't worry, I have the same problem as a 206 user, but it's not something to be afraid of.
this is not a malfunction but a feature (: guys, no matter how you know your lpg will be installed.
08.05.2020 15:32 # 17
metin
[QUOTE = shadow_okan] Best of all, let me get 25 TL of gas.I put 10 liters of gas in the trunk.We will put it in the bag where it is now.
you need to buy at least 7 liters of gasoline to restore the needle, which is about 30 TL.
08.05.2020 15:32 # 18
se®k@n
[QUOTE = mustiii] [QUOTE = se®k @ n] [QUOTE = mustiii]
After the last gas price changes, I did not calculate like any man; But let me tell you: I can go for 54+ km with 10 TL gas .. I think it is up to 18-18.5 krş down there. I okumus .. Gülme
08.05.2020 15:32 # 19
anil307
friends, when the subject is opened, let me ask something, I got the tup wasteer, I bought a gas of 15 TL, then I made 35 km when there was a gas, the light started flashing sonemice, do you think the tube is finished or do you think it decreased? When the vehicle's tube was over, the bell would not work. Let me highlight it.
08.05.2020 15:32 # 20
Japon
When the subject is painful, let me ask how much it burns at 1.4hdi km, I plan to get 206 1.6 110 and I am going to get a tube, it burns 25 kurus.
Japanese 2011-06-08 03:35:23
Page : / 2
