Exhaust Replacement
08.05.2020 17:03 # 1
phoenix.1905
Friends have an abart exhaust in my car and the head is cracked outside. I want to change it too. Will only the head of the exhaust I want to ask you change or will its complex change? I would be pleased if friends with knowledge on this matter help .. & nbsp;
08.05.2020 17:03 # 2
When you say head part, do you mean the most extreme tip part? If you mean the point where the last silencer connects to the middle silencer, you have to look at how much curume there is on both parts. If curumus is either replaced or welded. Of course, according to the situation.
08.05.2020 17:03 # 3
phoenix.1905
Yes, only the head part. To replace the head part, will it be cut from the source and replaced with a new one?
08.05.2020 17:03 # 4
SZKR
20 pounds of work. You like any exhaust tip, it ends. It cuts the rotten part completely and adds the tip there. As far as I can tell, it's not a case of changing all. & nbsp;
08.05.2020 17:03 # 5
phoenix.1905
Understood .. Thank you for your comments ..
08.05.2020 17:03 # 6
yigit4516
In this 306 there was a rot problem in the exhaust system. I also understood after the exhaust started to sound strange after using it for 2-3 months. I had the last muffler from God by changing it to 15 tly.
