exhaust problem
08.05.2020 16:15 # 1
durucuk
friends, there is a problem with the exhaust of the vehicle and will affect this fuel vehicle 307 1.6 gas & nbsp;
08.05.2020 16:15 # 2
I Love My Pug
Although it does not exaggerate, it does.
08.05.2020 16:15 # 3
durucuk
because I am going 96 km with 30 tl gas, I made the gas adjustment exhauster said the middle muffler and the last output should change both said traction & nbsp; and & nbsp; you will have a yacht problem
08.05.2020 16:15 # 4
I Love My Pug
He said it right, there is no increase in fuel but it burns a lot. What is the problem with the exhaust?
08.05.2020 16:15 # 5
taksicicocuk
My teacher affects the fuel is a different matter, but you need to change it for the engine urgently because the engine cannot throw the energy it needs to throw and the engine gets clogged. Let me tell the engine & nbsp;
08.05.2020 16:15 # 6
durucuk
Thank you very much for the information and how it would be useful if I installed a performance air filter on the vehicle.
08.05.2020 16:15 # 7
BurakGONULAL
[QUOTE = static] I would like to thank you very much for the information and how it would benefit if I installed a performance air filter on the vehicle ... [/ QUOTE]
I think I am also in the knowledge, by the way, how did you realize the problem in the exhaust?
08.05.2020 16:15 # 8
metin
[QUOTE = 307XT] [QUOTE = static] thank you very much for the information and how it would be useful if I installed a performance air filter on the vehicle ... [/ QUOTE]
< DIV>
I think I am in the team for the information, by the way, how did you realize the problem in the exhaust? .. [/ QUOTE]
& nbsp;
I'm using. There is no harm, no benefit.
& nbsp;
increases fuel. Tells lies too, fuel increases because you press the gas to hear the sound of an open air filter.
& nbsp;
so if you use the vehicle in the same way when you install an open air filter, both the fuel drops and the performance increases. it doesn't matter much but it has "+" even if it is 1%. This percentage varies according to the quality.
08.05.2020 16:15 # 9
redline
< div>
I think I am also in the knowledge, by the way, how did you realize the problem in the exhaust? .. [/ QUOTE]
Is this the thing you are talking about, like the occasional little bang sounds coming from the exhaust as bub bub? this incident exists in my exhaust and repeats several times even after stopping the vehicle
08.05.2020 16:15 # 10
taksicicocuk
IF I HAVE A TAXI, THE AIR FILTER IS SHOUTING TO THE CAR YAKIYO IS TAKING CLEAN OXYGEN TO BASMASSAN CAR AND LOW TO COME FIRE.
08.05.2020 16:15 # 11
sedataksu
[QUOTE = taksicicocuk] IF I HAVE A AIR FILTER THROUGH MY TAXI, YAKIYO TAKES THE FUEL EFFECT, THERE IS YAKIYO, BASMASSAN TO TAKE THE CLEAN OXYGEN The air filter does not help the vehicle. Only the sound causes you to increase the fuel as you put it on the gas and press it more. It makes a little headache. = "0" alt = "Grin" title = "Grin" />
& nbsp;
Taxi brother misunderstanding would you write me in lowercase. Big letter shouting means discussion. I wanted to remind asylum. "Laugh"
08.05.2020 16:15 # 12
taksicicocuk
I forgive everyone, I did not know that I took shelter for everyone, I learned something new.
08.05.2020 16:15 # 13
BurakGONULAL
[QUOTE = taksicicocuk] WHEN I HAVE A AIR FILTER THROUGH MY TAXI, YAKIYO TAKES THE FUEL EFFECT, THERE IS YAKIYO, BASMASSAN TO TAKE CLEAN OXYGEN
08.05.2020 16:15 # 14
durucuk
friends, my exhaust & nbsp; when i first gave gas, i mean it is making a pıty pıtr at 2 3 rpm the problem is that we should change this exhauster middle silencer and last output ...
08.05.2020 16:15 # 15
BurakGONULAL
In my opinion, it is not necessary to waste your money, I think so, oh my man, there is no effect on the fuel ...
08.05.2020 16:15 # 16
metin
[QUOTE = 307XT] [QUOTE = taksicicocuk] IF I HAVE A TAXI, THE AIR FILTER IS SHOOTING TO THE CAR, THERE IS A FUEL EFFECT, THERE IS A DIFFERENT OXYGEN TO THE CAPACITY OF THE BASMASSAN CAR
Since the burning process is not very healthy, we did not find any problems in the exhaust lpg in every exhaust, whatever you want, but we did not find the solution in the exhaust :) but after your contact is closed & nbsp; I was amazed to be so crazy in my own way ...
& nbsp;
Since there is no institution in LPG, the soot does not fill in the exhaust, so it extends its life instead of causing trouble in the exhaust.
08.05.2020 16:15 # 17
BurakGONULAL
by the way, I think the text is in the photo, it is transparent, light, light, fume devil :)
