EXHAUST, OXYGEN SENSOR, REAR STOPS
08.05.2020 17:43 # 1
106 Rallye
Hi friends, I have two questions for you. As I explained in the night, my car has the same engine with 106 rally gti. My first question is that the back left stop lamp is filled with water :( I could not find where the water came from.
The second question is, I made a super sprint exhaust kit for my car a little modified. 4-2-1 manifold 50.5 straight tube magnum end silencer. In the original exhaust, one of the oxygen sensors is next to the manifold and the other is next to the catalyst. There are two places in the supersprint manifold, one would be a bit far from the top if the other was down, that is, the katasator. Any problems or performance loss?
Since I am not a master in the country I live in, I am obliged to do it myself regardless of the problem. If you get an idea from you, I really do. :)
08.05.2020 17:43 # 2
106 Rallye
don't you have friends to help ???
I adjusted the oxygen sensor. It is longer than the wired one when I lift the car in the fiber.
I solved it but I couldn't solve where the water entering the stop light came from :(
08.05.2020 17:43 # 3
The water is probably due to aging of the gasket. I say with a good silicone.
