EXHAUST ODOR FROM THE VEHICLE
08.05.2020 21:24 # 1
atur
Hello friends. My vehicle was 2011 308 diesel sports. When I switch on the heater, there is an exhaust smell inside the vehicle. What could be the reason for this? I would be pleased if anyone who has experienced this problem or if they have any information will reply.
08.05.2020 21:24 # 2
omerb
Hello. Does the smell of exhaust come while driving in traffic. Or does it come when there are no vehicles etc. nearby?
08.05.2020 21:24 # 3
atur
It comes when there is no vehicle.
08.05.2020 21:24 # 4
omerb
There is a leak in the exhaust manifold or on the pipes. Or something like puncture. Look at the gold while the vehicle is running. Give someone gas. You will notice if the leak is large.
08.05.2020 21:24 # 5
atur
[QUOTE = omerb] There is a leak in the exhaust manifold or somewhere on the pipes. Or something like puncture. Look at the gold while the vehicle is running. Give someone gas. You will notice if the leak is large. [/ QUOTE]
thanks....
08.05.2020 21:24 # 6
atur
When the friends stood inside the car, the smell of the exhaust was very good. I recently opened the bonnet. I removed the engine cover and when I looked it was leaking from one of the injectors. throws smoke. I talked to the master, said the master injector stamps will change, let's see. I will inform you when the transaction takes place.
08.05.2020 21:24 # 7
yuceakgun
Hello Atur,
While browsing the forum, I saw the subject you had opened. I have a problem just like you, I thought it was coming from outside. If you solved the problem you had in your vehicle, can you share information?
08.05.2020 21:24 # 8
Peto
Hello, I became a new member and I have the same problem in my vehicle. My vehicle is coming from the 3rd injector in 172,000.
08.05.2020 21:24 # 9
yuceakgun
Hello there,
I also took my vehicle to the master on Saturday, asked me to look at the injectors in the cold state of the engine. As a result of the checks I made, I saw wetness in the third injector, and I probably have a problem there. I will take it and show it to me again soon. I will inform you in the developments.
08.05.2020 21:24 # 10
308hdi11
If you previously disassembled DPF, the clamp attached to the turbo side may not be tightened completely. Or it may have been loose. I know it happened to me before.
03.06.2020 15:20 # 11
unalll
Hello, Similar problem happened with my car. About 3 weeks ago, I went to Demirkan Automotive in Başkent Oto Sanayi. Leakage was detected from the syringe seal. 2 Injector seal, feet fixing all injectors, air and pollen filter changed. I paid a total of 365 TL. The process took about 30-40 minutes. Problem solved, no problem left.
