Exhaust fumes at first start up in 207 mornings
08.05.2020 15:20 # 1
fahri_y81
http://www.youtube.com/watch?v=vouvkxxverw
Guys, in the video I gave in the link above, there is a video about the smoke coming from the exhaust in the first start when the engine is cold in my car. I wonder if this is a problem. For this, I showed it to 2 different services 3 times and was said to be normal. If I have experienced friends, if I can get your comments on this issue, maybe I will be comfortable. If there are problems, it may cause.
08.05.2020 15:20 # 2
furkan
the first 20 thousand km in new vehicles does not do when the engine gets
08.05.2020 15:20 # 3
fahri_y81
[QUOTE = furkan] does the first 20 thousand km for new vehicles, the engine does not get used to [/ QUOTE]
Doesn't it hurt my head later? I do not want to pay out of pocket after the warranty is over. :)))
08.05.2020 15:20 # 4
hhuzun
take a look at the injectors.
08.05.2020 15:20 # 5
marasov
Do not do anything if it is a new vehicle
I don't know if it will be useful, but if you are using the vehicle hard, wait 20-25 seconds before you hit it.
08.05.2020 15:20 # 6
fahri_y81
I do not use the tool hard.
I wait 20-30 seconds when I run it, I act like that
After I come down the road and wait for a while again, I stap
but there is always doing. The vehicle is a new vehicle at 4 thousand km.
Services do not suspect anything. All they say is normal.
Maybe I don't know normal
08.05.2020 15:20 # 7
furkan
In new vehicles, especially in the first 20000 km of diesel, oil reduction is normal in the first 20000 km.
08.05.2020 15:20 # 8
fahri_y81
[QUOTE = furkan] In new vehicles, especially in the first 20000 km of pejo, diesel oil loss is normal in the first 20000 km, this oil is decreasing during boring.
I hope there is no problem.
08.05.2020 15:20 # 9
furkan
In 2008, we got zero 207, we went to the service for the first maintenance, 2 liter of oil remained in the crankcase.
08.05.2020 15:20 # 10
I don't think it will be a serious problem, but I would recommend you to have a service that understands Peugeot again.
08.05.2020 15:20 # 11
okan0665
This problem is taken care of by the service records, then this part is not under warranty, you did not bring it in the first 2500, etc. they draw side by side. I also had a voice coming from the vehicle, I said it when I took it to the first 2500 maintenance, they said we did it and gave the vehicle, but the problem was not solved. When I took it in 15000 maintenance, they said that the sound was caused by the shock absorber, they should change it, if the shock absorber fails for the first 2500 km, it would be replaced under warranty, or it would not be changed. I had the same problem in 2500 maintenance, it could not be resolved, I said if you want to see your records, I changed the piece they wanted for 160 TL without any payment.
