Exhaust emissions and shifting
18.03.2022 20:47 # 1
veysel152
Hi guys, I'm new to the
Forum. My car is Peugeot 207 Vti Feline CC 2011 model at 160,000 km. It has had an occasional steering lock issue for a while. The vehicle was driving on its own as if you had it idle. Today, I read the comments on some forums and pressed the gas when it was idle and it went up to 6000 rpm. Then the stop sign came on and it was like I wasted it as usual. Now the gear does not shift, the car does not start. What do you think could be the problem? Thank you.
20.03.2022 19:35 # 2
antipollution
Brother, I came to the topic to help you, but I think your problem is a bit beyond us. Steering lock can be a separate issue, not shifting gears can be separate issues. There seems to be more than one problem that a good master needs to examine well. If the steering wheel locks while driving, it can be vital. Attention
22.03.2022 18:08 # 3
Steering problem usually makes it from ignition, have it checked. but if the steering pump is faulty, the steering may become very stiff, the pump probability seems to be higher. Is the car automatic by the way? If you are facing this problem at high revs, first change the coil spark plug and fuel filter. It will be better if you have the fault codes checked with the original device. so that we can assist.
28.03.2022 09:53 # 4
veysel152
thank you for the replies. vehicle automatic. I think it's because of the gearbox. It cost 15,000. It seems like an exaggeration, but there is nothing to do.
28.03.2022 10:55 # 5
antipollution
get well soon bro, but I wonder what does the steering wheel have to do with the transmission? I'm asking because I don't know, but it sounded a bit strange. It would make sense if there was a front gear or something, the transmission seemed a bit strange to me in the future. When it comes to 15 thousand liras, it may be true if the transmission will change completely, we paid a lot of money even when buying a transmission for your friend's old car.
