Exhaust Emission Malfunction
08.05.2020 20:56 # 1
Ulas02
Hello friends. My car is the Peugeot 308 1.6 VTI Automatic Gasoline 2009 model. Last week, Exhaust Emission Fault warning was given on the screen. The problem was cleared by connecting to the computer. But yesterday he gave the same warning yesterday. The repairman friend said that the Map sensor is broken. There is also the problem of eating gas. Do you think as the mechanic said? Ulas02 2018-07-02 15:14:28
08.05.2020 20:56 # 2
catalyst may be full of exhaust emission failure. I connected the pc and looked at the fault codes, brother.
08.05.2020 20:56 # 3
Ulas02
Yes, he connected the pc and cleared the error code, but after 2 days the brother gave the same error again.
08.05.2020 20:56 # 4
Here are the error codes, my teacher, if you took note of this, there may be many reasons for this problem.
catalysis is
-spark plug
-coil
- oxygen sensor
-map sensor, but it is not a piece that easily breaks down, you have to try and clean it.
08.05.2020 20:56 # 5
Ulas02
The repairman I showed said the map sensor according to the error code. He also connected his failure to eat the gas to the map sensor. Since he could not find the sensor, he just deleted the error code and forwarded it to the service. Prices are between 150-200 TL. It starts with 300 liras at the service. I will try to wear it myself. Thanks
08.05.2020 20:56 # 6
ercanayman
Hello,
it gives me the same error from time to time. I'm waiting a few days, the error disappears by itself.
But my opinion is due to bad fuel or burning problem.
If it takes a little longer to get the error, I take good fuel and root the gas several times. what is usually the problem that day.
Always show if the engine light is on for a long time, for example, about 10-20 days. Then, problems arise from the burning problem.
08.05.2020 20:56 # 7
uurgzl
I also have a 308 vti 2009 model.58 thousand km de.lpg no. Exhaust emission system malfunctioned error too. I got the fault light after receiving fuel from different place . He wrote temporarily. After a while, he burned again and the fuel I thought was dirty was still in the tank. then I ran out of that fuel and took the würth injection cleaner and bought gasoline from where I always bought it. Then I connected it to the pc and deleted the fault. Let's see what happens? etc. in the departure of the vehicle. no problem, but the human is disturbed. Let's see what happens? what is your solution
Then it burned again after 10-15 km. If the solution was clear, I would have it done directly, but I don't know how to be solved?
uurgzl 2018-07-17 00:28:35
08.05.2020 20:56 # 8
ibrahimdcan71
Friends 2010 vti lpg car 130 thousand I receive an exhaust emission warning. However, this happens in the mornings, the vehicle is kicking, it does not eat gas, this warning is coming. It goes out in the light of fault ..
08.05.2020 20:56 # 9
Simuzer
the main reason for this problem is the difficulty in comparing the first oxygen sensor with the second oxygen sensor measurements. there are a few possibilities that makes this happen.
1. Foreign matter is removed in the fuel received, it is instant. passes on the next close purchase.
2. A particle has come to the oxygen sensor probe. At high speeds on the long road, this particle can be displaced by moving.
The 3rd oxygen sensor has failed. needs to change.
4. If the oxygen sensor is intact, the catalyst cannot clean sufficiently. So it is full. needs to change.
08.05.2020 20:56 # 10
Ulas02
Hello friends. The friend of the engineer at the Peugeot service said that the exhaust emission warning will give a warning unless the error code is cleared. He also gave this warning in other malfunctions. But the main problem is to pay attention to fuel purchases. After that problem, he did not give a warning when he took the fuel from known companies.
08.05.2020 20:56 # 11
Thanks for the information and feedback, hodja.
08.05.2020 20:56 # 12
hulya1558
I will write the same problem yellow warning is burning emission error I read the comments thanks friends
08.05.2020 20:56 # 13
nurti55
Hello friends,
I bought 308 SW 2009 a few weeks ago. Just like you, the exhaust emission error in my vehicle has been reported. I deleted the warning, I had the catalyst and particle cleaned, but it did not improve. Then I realized that when it goes to high speeds (estimated 150 km -160 km), the vehicle gives an error message and the malfunction lamp lights up (exhaust emission error). Yesterday I took the vehicle to the industry again, they made a few hose changes and turned off the malfunction lamp. But on the way back home, I said to speed up and try the car. Again, after 150 km, it gave an error and even the temperature indicator of the vehicle rose suddenly and the hand came to an end and gave a stop warning. Immediately I opened the heaters, pulled aside and waited 5 minutes later, the hand gradually dropped to 90 degrees. I wonder what could be the real source of the problem.
08.05.2020 20:56 # 14
[QUOTE = nurti55]
Hello friends,
I bought 308 SW 2009 a few weeks ago. Just like you, the exhaust emission error in my vehicle has been reported. I deleted the warning, I had the catalyst and particle cleaned, but it did not improve. Then I realized that when it goes to high speeds (estimated 150 km -160 km), the vehicle gives an error message and the malfunction lamp lights up (exhaust emission error). Yesterday I took the vehicle to the industry again, they made a few hose changes and turned off the malfunction lamp. But on the way back home, I said to speed up and try the car. Again, after 150 km, it gave an error and even the temperature indicator of the vehicle rose suddenly and the hand came to an end and gave a stop warning. Immediately I opened the heaters, pulled aside and waited 5 minutes later, the hand gradually dropped to 90 degrees. I wonder what could be the real source of the problem. [/ QUOTE]
good vehicle. I wish you could use it without any accident. Where do you buy the fuel, teacher. Get a quality injector cleaner, fill it with a quarter stick and add 100-150 TL of fuel. then use a bit of 4 gears at high revs will probably pass. but don't forget to write down the error codes somewhere, we make more solution oriented explanations accordingly.
08.05.2020 20:56 # 15
nurti55
Thank you for your interest and concern.
I usually buy my fuel from Shell or Opet. I want to do what you say, but when you push the vehicle a little, the temperature hand rises above 90. Late, I realized that they added a sensor to the radiator hose. I wonder why the vehicle could overheat this hose.
I will definitely write down the error codes next time.
08.05.2020 20:56 # 16
[QUOTE = nurti55]
You're welcome, if you can post a photo, it will be more helpful. Do not weigh too much fuel except shell. It shouldn't be over 90, hodja. perform a radiator cleaning, in addition, replace the circulation pump. antifreeze from the red one. so observe it. the sender they put in may probably be the temperature sender. they may have canceled the sender on the thermostat.
sonerkyl 2019-11-19 08:47:30
08.05.2020 20:56 # 17
ismailkaya
I know that if the maf sensor fails, the vehicle will stop and unplug the sensor, and your problem may be related to the sensors in the catalyst.
08.05.2020 20:56 # 18
ismailkaya
08.05.2020 20:56 # 19
pejo40
Hi everyone, my name, I agree with you from Kırşehir. There are 308 diesel for 8 years. 100 thousand has not had any problems so far, the other day I filled the intercity warehouse to opete, and after a while it gave the exhaust emission error and esp error gas cut tremor. I came up to Kırşeh with such a 40-50 rpm without upgrading.
I took it to the industry in Kırşehir. Everyone has a non-original device and they look at it. One gave injector 2 error. One gave injector 3 error. Let us put the engine and find it for 3-4 days. Meanwhile, I use my car at low speed all the time. I would be happy if you help what I need to do.
08.05.2020 20:56 # 20
BayQ
Sefa Bey, all of your vehicle's catalyst hold sensors, egr injectors need to be cleaned. Diesel vehicles should not be used calmly. If you do not need cycles, it would be best to change the engine of your vehicle if it does not have maintenance and cleaning in turbo.
Page : / 2
