Exhaust emission failure - Acill
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 3008 (2009-2015)
08.05.2020 21:00 # 1
GuideofTurkey
Hello Friends, I bought the 2010 model 3008, I'm new to the forum. I would like to receive your comments and suggestions on a subject;
My car lit the yellow engine icon malfunction lamp yesterday and gives Exhaust emission failure warning.
I am on holiday in Izmir, can I return to Istanbul in this way?
Please write an urgent experience with the subject.
08.05.2020 21:00 # 2
GokhaN
Hello, good luck of the vehicle, did you get any warning of particulate fluid too
08.05.2020 21:00 # 3
Selcuk55
Make the first dpf and adblue maintenance. Now there are places that perform dpf cleaning, connect it to the machine and keep in mind.
08.05.2020 21:00 # 4
ismailkaya
After you have not received a stop warning on the road, use the car at high speeds. Those before you used the car as a gasoline. Does it burn fuel too?
08.05.2020 21:00 # 5
First of all, welcome to us. good vehicle. As our friends said, it was probably because the vehicle was used without a roll.
08.05.2020 21:00 # 6
GuideofTurkey
Thank you, master, no he did not give such a warning
08.05.2020 21:00 # 7
GuideofTurkey
Thank you Selçuk, will it pass when you do these? Second, is it necessary?
08.05.2020 21:00 # 8
GuideofTurkey
Thank you, Ismail. Yes, the performance is also about hoarse and burning more than mentioned in fuel. Why do you think it originates?
08.05.2020 21:00 # 9
ismailkaya
I think you need to replace the sensors in the catalyst and lamp. I know it is very salty but it is also used for catalyst cleaning, but I don't know if anyone makes the sensors
08.05.2020 21:00 # 10
ben_erhan
If you say that the friends used the vehicle without a cycle, the vehicle is an automatic vehicle .. the speed does not raise the gear, you are right when you say it, but it goes against the logic.
08.05.2020 21:00 # 11
HasGur
[QUOTE = ben_erhan] friends say that they used the vehicle without reversing, the vehicle is an automatic vehicle .. the speed does not increase the gear if it is not known, you are right in what you say but it goes against the logic. / quote]
What is the shift speed in automatic vehicles? Can the driver use shifting at 2000 rpm or 4000 rpm without any manual mode, or at any speed it wishes?
08.05.2020 21:00 # 12
cvheneburi
Hello friends, I also have 2015 3008. I got the urea warning and 1100 km after the starter ban warning and also the engine malfunction started to burn. I added adblue but it didn't go out. The nearest authorized service is 250 300 km away. The masters here are connected to the computer and the fault could be deleted. I do not want to trust them very much, but frankly, I am afraid to stay on the road until the service goes far.
