Exclamation mark in triangle
08.05.2020 17:42 # 1
usasd
While friends are on the way, it happens once in a while, an icon with an exclamation in the triangle sign appears on the display and it gives an electric circuit warning on the road computer.
08.05.2020 17:42 # 2
error
Are there any changes in the lighting components in the vehicle? led bulb, xenon or something?
08.05.2020 17:42 # 3
usasd
xenon headlight
08.05.2020 17:42 # 4
usasd
xenon headlight has already started but it has just started making
08.05.2020 17:42 # 5
Bugra
Although I am not very sure, I say the pads may be running out.
08.05.2020 17:42 # 6
emre_akdag
yes there may be a lining warning.
08.05.2020 17:42 # 7
fexzi
In a triangle, exclamation means ESP in most vehicles, what is the model engine of your vehicle?
08.05.2020 17:42 # 8
qqyyxx
When you move without closing the doors in those triangle makeup cases, it gives a flashing warning, states a situation related to the electronic component, it may be simple, but it is useful to check the connection to a pc.
08.05.2020 17:42 # 9
outlaw
http://yasinoto.com/ikazlar.asp
MAYBE MAY HELP GENERIC FAILURE BUT I DID NOT UNDERSTAND ...
08.05.2020 17:42 # 10
usasd
I don't know, but when you brake, it sounds a little bit like a motorcycle is braking
usasd 2013-06-14 14:18:21
08.05.2020 17:42 # 11
usasd
My car 307 1.6 engine automatic
08.05.2020 17:42 # 12
Bugra
If it sounds like a metal hitting the metal when braking, it means that it is finished. hars hars sounds like hars Big smile
08.05.2020 17:42 # 13
Bugra
The bidet says esp under fame in the yellow triangle that those friends call. I guess yours isn't her. There is only an exclamation mark in the red triangle. It lights up when the parking brake is applied.
08.05.2020 17:42 # 14
usasd
While burning on the road in the yellow triangle, it burns at once, sometimes it goes through the bump, it turns off when the ignition is switched on and off
usasd 2013-06-14 16:49:59
21.07.2025 00:13 # 15
Salihsencan
[QUOTE=fexzi]The exclamation point in the triangle means ESP in most vehicles. What is the model and engine of your vehicle?[/QUOTE] The EPS problem has been fixed but the same problem persists. What should I do?
