Excessive whistling sound
08.05.2020 18:51 # 1
forbid55
Hello,
I have read the previously opened topics, they wrote that the whistling sound is over, but I would like to ask if it would be OK to use it in this way.
My car lay down for about 1 year, this was not a problem before, now when I press the gas, I get enough whistling noise and I feel low on traction unless I am so overpowered. Vehicle 307 1.4 HDI.
I am not someone who presses too much gas, I use the car between 2000-2500 rpm.
Do I need to replace or repair the turbo, or do I get more work if I say go where it goes?
Thank you for your help.
Accident-free driving.
08.05.2020 18:51 # 2
peugeotefe
Your vehicle will probably break the turbo pali if there is an excessive whistling sound. If it changes, it will be healthy.
08.05.2020 18:51 # 3
oguzhan29
anyway, it is useful to have a look, hodja
08.05.2020 18:51 # 4
samet206
If you ignore the engine, the master is nothing else, it goes as far as it goes, there is no problem in it. I think you should repair it as soon as possible.
08.05.2020 18:51 # 5
ahmet_bjk
I advise you to check the turbo hoses first, any cracks, leaks both make noise and lower the vehicle from traction
08.05.2020 18:51 # 6
forbid55
Thank you for your answers, the detour appeared to us again.
