excessive vibration problem
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 14:06 # 1
tugrabozan
Hello to everyone. My vehicle had a shaking problem in my car than the 406sv gasoline sedan, they said about the axle in Antalya. I do not come to load right now I came to Istanbul for a short time, let's get it done while the locals here come here who knows if there is an address phone. thanks in advance.
08.05.2020 14:06 # 2
My brother's engine ear, or the chock, which usually distorts the transmission ear, if it sounds like he plugs it into the vehicle 2, load it on the light gas, it immediately installs check gas, the transmission ear needs to be changed.
08.05.2020 14:06 # 3
hasimayaz
Very likely to be from the ear on the transmission side
08.05.2020 14:06 # 4
Murat
I had the same problem a few months ago.
I do not know the name of the part, but there is a triangular part to which the gearbox is attached, 2 of those bolts are broken and one is loose. I don't know the same in 406, but I think you should look at that piece.
08.05.2020 14:06 # 5
Onur
[QUOTE = polatkaptan] my brother's engine ear, that is the wedge usually distorts the transmission ear, if it sounds like it plugs into the vehicle 2, go to the idle, load the gas at once, the transmission ear needs to change [/ QUOTE]
08.05.2020 14:06 # 6
tugrabozan
I changed the gearbox wedge. But when I get in the car it does it again but not very often
08.05.2020 14:06 # 7
tugrabozan
the gearbox wedge does not have a cast aluminum part with a long axle bearing bearing, is it on the exhaust side, there are 3 wedges I found in the car
