Excessive vibration in gear when vehicle speed increases
08.05.2020 19:53 # 1
FatihTuncel
Hello friends, I am new to the forum, I was actually following it from the outside, but it was fortunate to participate inside today.
First of all, the problem is that for a short time, 106 Quiksilver has a tremor that shifts as the vutes passes, and if I have the opportunity to shake the gearbox, it will come to my lap so that it will not shake the gearbox.
08.05.2020 19:53 # 2
samet206
This kind of a problem happened to me as I pressed the gear lever was shaking, the problem came out of the axles.
08.05.2020 19:53 # 3
FatihTuncel
How was the problem exactly as it accelerated and the cycle increased, was it shaking?
Could there be a problem other than the axle? Because the vehicle does not play shafts, I just know that the whole problem in gear is like gearbox failure. There is also a distinctive feature, the first brake was started with this fault.
08.05.2020 19:53 # 4
samet206
There was no change in the vehicle, there was no acceleration, etc. There was no shifting, only the gear lever was playing.
samet206 2016-06-27 21:44:37
08.05.2020 19:53 # 5
FatihTuncel
Thank you bro, I will look at the problem as soon as possible and share it here.
08.05.2020 19:53 # 6
welcome fatih have a check on the transmission clearing.
