excessive sounding of the steering pump
08.05.2020 20:57 # 1
mtemuz
Hi friends, Muhammet, I have a 2011 diesel 308 vehicle. For about a month, when the vehicle is in motion, there is an excessive whistling sound when I turn the steering wheel. this sound does not always happen. It turns out at uncertain intervals. When I took it to the master, I did not hear my luck. I wonder what could be the reason for this disturbing sound. I would appreciate if you help.
Meanwhile, the level of steering oil is sufficient. there is some stiffness in the steering wheel.
Thank you in advance for your help.
08.05.2020 20:57 # 2
First of all, welcome to us. The problem is probably the repair of the teacher from the steering pump is possible. They usually do the repair around 300-400 TL.
08.05.2020 20:57 # 3
mtemuz
thank you for the answer, hodja
then we hope we will not be on the road until the repair is done.
I think only pump coals are being changed. is it true?
