Excessive Ramp Shaking
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 2008
07.03.2021 23:04 # 1
hakan76
Hello to everyone
I have some kind of unsolvable problem 2015 diesel automatic 2008 I have no problem in the car normally, but when we reach the ramp on a long slope, the whole car trembles when we press the gas, the whole car falls off the power when you take your foot off the gas It returns to normal, if the ramp is not finished, trembling starts again when the gas presses. The bad thing is that he does not always do it on the straight road.
They said the pressure lining, I changed it, they said the flywheel, I changed it, they said axle.
You think we are desperate. I wonder if it has happened to you before.
Thanks in advance
hakan76 2021-03-07 23:04:23
08.03.2021 09:19 # 2
Hello, sir, I have practiced the gearbox after the pressure flywheel change. Other reasons can be caused by parts such as injectors and airdebimeters. In addition, the gearbox and engine ears were checked.
08.03.2021 17:26 # 3
hakan76
Hello, I do not know if the gearbox exercise was done, frankly, the injectors came to mind first, it turned out clean, the gearbox and the engine ears were looked at. The latest master gearbox also made a sentence as it may be a production error, it must be changed completely. I do not understand much, but how it could be a production error did not lie in my mind. I wonder if anyone has come across such a situation? Let me also ask about the weather meter. Thank you for your interest.
09.03.2021 03:13 # 4
Emre66
It had happened to me, such an event had broken the spring in the axle
