Excessive noise in the engine.
08.05.2020 20:38 # 1
rmustafa
SA Friends. My car is the Peugeot 307 2006 model. Gasoline + LPG fuel system is available. While my vehicle has been in both LPG and petrol for the last 1 month, the engine has a hitting sound. I'm also throwing your video. What is the reason?
[TUBE] 8m2jq5woj the [/ TUBE]
08.05.2020 20:38 # 2
peugeotefe
Does the sound come from the bottom or the gas from the top, change the sound, etc.
How this problem started can be understood from the video as if hitting the bed but you have to see the video misleading live
08.05.2020 20:38 # 3
Peugeot35
It is like valve sound, show it to the service.
08.05.2020 20:38 # 4
rmustafa
[QUOTE = peugeotefe] Does the sound come from the bottom or change from the top when gas gives off, etc.
How this problem started can be understood from the video as if it is hitting the bed but you have to see the video misleading live [/ QUOTE]
Coming from the top, my voice.
08.05.2020 20:38 # 5
tolgakmg
Good Morning. The voice you are talking about is obviously the senses, the sound of "knock knock" ... or do you mean wheezing from the deep? Does the vehicle have oil smoke or low traction? Does the sound stop when you press the gas? How is the sound in constant gas or high revs?
08.05.2020 20:38 # 6
peugeotefe
If the sound is coming from the top, it may come from the material we call pushing, it may not fill the pushers.
08.05.2020 20:38 # 7
rmustafa
Tak Tak voice, sir. Yesterday when the engine was running, I looked at the dipstick and the level was good and there was no smoke output. There was a low traction. It was the first time, but it was due to gasoline. When you buy gasoline from Shell, there is no problem in traction. but the rattling continued. Hodja, when he presses the gas, there is a click. I also bought this click ass gas and gasoline sometime. I didn't know oil was bad. it started after that. The traction was reduced but when it was removed from the rack, the traction improved but the engine did not.
08.05.2020 20:38 # 8
peugeotefe
In the first place, the coil and injectors should be looked at, if there is no problem, the top of the piece, which is called the tapet cup, which we say will push it, may have burned in the valve in relation to the abrasion of bad fuel over time.
08.05.2020 20:38 # 9
rmustafa
Problem solved. There are 4 small tube pipes connected to the engine, one of them was missing. They said Manifolt, but it's not too costly. The scuba man takes care.
08.05.2020 20:38 # 10
onlycihan
be happy with it because it is not costly for you
