Excessive idling when the vehicle is cold
08.05.2020 21:07 # 1
ikame
Hello
I am writing from Izmit. My car model is 207 1.6 vti automatic, model year: 2008
It has been 2 months since I bought my car. 2 days after I took my car, I traveled about 600 km long road, the first 200 km of this journey had no traction, but after a long journey, the engine malfunction lamp came on the screen and it gave faulty failure. I did not sense anything abnormal. In the first time, only in the morning, the first run showed an abnormality in the first run in the morning, and when the speed came to the master to detect the fault, I said that the vehicle jumped to the synthesis and had to be corrected. gave it and started to vibrate when I brought it back to the master again, it was said that 1 coil was broken. Although my vehicle is shivering, the tremor in the roles (when I run in the morning is too loud and unbalanced in the morning) it continues to misfire, and I want an idea without knowing what to do without a car. .
08.05.2020 21:07 # 2
GokhaN
hi how many thousand of your vehicle
08.05.2020 21:07 # 3
ikame
My teacher at 144000km,
Trembling in the vehicle is not felt when driving
When I replaced all of the coils 2 days ago, the engine malfunction lamp was spontaneously turned off and returned to normal when the vehicle was running when it was hot. When I started this morning, the tremor problem showed up again with the engine malfunction lamp. Also, in 3 weeks, the vehicle decreased about a little liter of oil.
08.05.2020 21:07 # 4
deneme51
You change the master first, I think, Master, I think that if the idle car goes that far, it will damage the inside. The error it gives is dirty fuel and catalytic failure. Show your car to the pejo master, I think don't forget to measure the rollers. Look at your spark plugs. if you are using a clean, last note tool with lpg in time it is right to the butterfly, it shows malfunction and idle imbalance due to dry fuel
08.05.2020 21:07 # 5
ikame
They said that I measured the pressure values of the cylinders in another service, it is normal,
Catalyst aging between faults emptied before the catalyst gives me error, together with the oxygen probe
Let the throat butterfly and the idle motor look at it, but that supply is now the cost of the world,
Thank you
08.05.2020 21:07 # 6
ikame
Also, I am waiting for your advice if there is a master around you in Izmit that you think you can make the right determination.
08.05.2020 21:07 # 7
deneme51
Master Master is not a malfunction of the world.
Meanwhile, all LPG pejoes that do not adjust AFR turn on the malfunction lamp. you get what you say or make it look up to 150 lira
deneme51 2019-01-15 23:50:35
08.05.2020 21:07 # 8
ikame
Thanks to my teacher, a good master who understands the peugeot language was a must.
I am open to advice and ideas.
08.05.2020 21:07 # 9
deneme51
Unfortunately, I am meaningful too. I do not tamper with anyone, I take my vehicle to the special service of Izmir. Excuse me, I did that fool before they broke the transmission of my solid car and found the water in me so take it to the master, give me 5 lira more deneme51 2019-01-16 00:13:23
08.05.2020 21:07 # 10
Xpower
You can show it to Yüksel Peugeot on the Small Gulf industrial site
08.05.2020 21:07 # 11
eneserhat
The problems you mentioned were also in my vehicle (2006 307 sw). Yesterday I gave it to the mechanic first, the coil spark plugs changed. When the problem persists, now he will change the butterfly and try it (take it from the printer). For now, 950 TL has been released, Shocked The piece called butterfly is at least 500 TL.
How can I find that piece, he threw in his picture but I couldn't add it here? 9649510080 He writes a code like 02.
eneserhat 2019-01-16 09:47:03
08.05.2020 21:07 # 12
[QUOTE = eneserhat] The problems you mentioned were also in my vehicle (2006 307 sw). Yesterday I gave it to the mechanic first, the coil spark plugs changed. When the problem persists, now he will change the butterfly and try it (take it from the printer). For now, 950 TL has been released, Shocked The piece called butterfly is at least 500 TL.
Do not give more than 250-300 TL for the zero zero of 560 TL.
08.05.2020 21:07 # 13
[QUOTE = substituted] Hi
First of all, welcome to us. You have replaced most of the parts that may be a problem. Keep riding on gasoline until this vehicle is straightened. other places to check my teacher measure the pressure of the gas pump and have the gas injectors checked. Also, unscrew the solenoid valve and have it cleaned. the catalyst is empty because there may be two oxygen sensors in the vti engines, if it cannot read the correct values, the map values of the vehicle are constantly variable and disrupt the working order of the vehicle. Of course, as our friends say, without forgetting to find a good peugeot master, vti engines were also used in bmw and mini vehicles. Get well soon.
08.05.2020 21:07 # 14
eneserhat
I'd better find that price, but I don't have much time to visit industries. I do not want to seek permission from work. As long as you don't get cold, our lion.
08.05.2020 21:07 # 15
[QUOTE = eneserhat] I'd better find that price, but I don't have much time to visit industries. I do not want to seek permission from work. As long as you don't get cold, our lion. [/ QUOTE]
Sir, if you don't have much time, you can order from such sites.
08.05.2020 21:07 # 16
ikame
We are welcome, Hodja,
After my car got warmer, the shake of vibration also decreased,
I have consulted a number of different peugeot vehicle masters and the adaptation is about the throat butterfly,
08.05.2020 21:07 # 17
[QUOTE = substitution] We are welcome, sir,
I hope your problem will be improved after my teacher adaptation
08.05.2020 21:07 # 18
ikame
InsaAllah teacher thank you
08.05.2020 21:07 # 19
Nurettin46
hello, I would appreciate if you write the result and the reason, regards, by the way, my vehicle was 2011 1.4 vti 120 thousand and I had a subject in my yes. It takes a minute or so, shaking, I mean when it warms up, if yours does not. Nurettin46 2019-01-18 22:11:53
08.05.2020 21:07 # 20
eneserhat
[QUOTE = sonerkyl] [QUOTE = eneserhat] I could find it at that price, but I don't have much time to visit industries. I do not want to seek permission from work. As long as you don't get cold, our lion. [/ QUOTE]
Thanks for your advice, the problem was in the valves, not the throat butterfly. What my master said was that he was working late in the morning and idling imbalance because he melted lpg valves. He said that as long as you use LPG, the valves will melt again after 80-100 thousand km. It cost me 4000 tly. Peugeot service also said that we do not recommend LPG in vehicles before 2010.
I wish I had read this article before I went to the service. Then I would solve the problem with 2,000, not 4,000. But it was a lesson.
"Valve Melting Symptoms
As the valves begin to melt, the engine begins to show signs of malfunction gradually. The engine does not start at cold start at the first start, and later on idling the vehicle runs erratically and vibrates. The maximum speed of the vehicle in each gear is very noticeably reduced until the engine valves are completely melted. "
eneserhat 2019-01-21 21:46:31
