Excessive engine oil pressure warning
02.08.2022 21:01 # 1
Halilbb
Hello friends, when my vehicle is 1.4 miles and has been driving for a few months, when the engine warms up, after 15 km, when it stops at the red light, an excessive engine oil pressure warning comes on, the oil lamp comes on and the vehicle says stop. I changed the oil sensor, I bought the original filter, I changed the oil from the dealer in europar, it still didn't work. The master in europar said that the cylinder head needs to be changed. I asked many masters who said it's because of the fan or the oil stick or the oil pump... I got cold from the car, thank you if you can help
03.08.2022 12:06 # 2
Sir, the problem is probably either the oil pump or the engine oil canals are blocked.
03.08.2022 17:17 # 3
Halilbb
I changed the oil, sir, it's not from him
03.08.2022 17:18 # 4
Halilbb
It could be the pump as well, I don't know about the blockage, I didn't have him look at it.
09.08.2022 14:53 # 5
metin70
Mr. Halil, if your vehicle is LPG powered, have the engine cleaned, then have the oil pan removed and cleaned thoroughly, especially the area where the oil strainer is located. Use Hella brand as a contactor. I followed this path in my vehicle. Of course, use the original oil filter as well.
11.08.2022 00:01 # 6
Fuatyildirim
Greetings, if you connect your car to the original diagbox device and throw the fault code, we will help you.
11.08.2022 14:54 # 7
KILIC
In my opinion, it is absolutely necessary to connect a pc with the original peugeot software and act according to the error code.
