examination
08.05.2020 19:56 # 1
orch
Friends will have a few questions for the examination;
1) Does Angel headlights undergo examination?
2) Does the Varex controlled exhaust undergo inspection?
3) There is a carbon coating on the roof of the vehicle.
08.05.2020 19:56 # 2
Onurzdn
I went to the new examination parks led di wrote as a slight defect, the color goes against the regulation, and angel goes against the slight defect, but I can not say anything to the exhaust event
08.05.2020 19:56 # 3
headlights and ceiling can not be a problem. exhaust problems may occur.
08.05.2020 19:56 # 4
Firtina61
Inspection repeat if the roof is different from the vehicle color.
08.05.2020 19:56 # 5
Gokcesel
The headlights will not be a problem if the xenon is not installed.
I'm not sure if the exhaust will pass, unfortunately.
If you come to the ceiling, try your luck 2-3 months ago, my brother had entered the ceiling covered with piano black, maybe they will spend you too. He was under examination immediately.
08.05.2020 19:56 # 6
usta42
If it is different from the vehicle color, they keep the vehicle modification report, they go to the traffic with that report, they change the second page of the license and process double color.
08.05.2020 19:56 # 7
ozgorh
They've done the exhaust past, the build-in shop outside.
08.05.2020 19:56 # 8
ozgorh
If 2 leaves change, 187 single leaves changed 84 odd meanwhile at 8th of the month
08.05.2020 19:56 # 9
orch
Thanks guys for the information you provided ...
