Everything is wrong !!!
08.05.2020 16:46 # 1
arifkemal
Hello friends, some of you remember maybe I already had 206 vehicles before, now I bought a 2004 model automatic 307. I have a new problem with my car. First, the sunroof started to not shut down, and then all the malfunction lamps of the vehicle started to burn. It goes back to normal for 2-3 minutes, sometimes an air bag fault gives an abs fault, the windows start to hurt, the tape is silent, the indicators go to zero, but the car continues to go while these are happening. Run the island where it stops. My head was a world, I couldn't understand. Can anyone help if it happens?
08.05.2020 16:46 # 2
toga406
ahh here is the story of pejo. comfort is good but when it goes wrong, things will get frustrated
08.05.2020 16:46 # 3
berk2309
all indicators gasoline overheating speed & nbsp; vs don't work freaking out:) & nbsp;
08.05.2020 16:46 # 4
berk2309
When the blade stops and runs again, does it disappear after a while? & nbsp;
08.05.2020 16:46 # 5
my teacher charging station is fixed with experience. There is no guarantee if you have it repaired. I had it repaired once 3 months later it broke down again. In addition to this, my power steering was canceled. the tachometer was constantly playing, then we replaced the original 750 tlye in the service and we fixed the problem
08.05.2020 16:46 # 6
toga406
more 2007 model 207 hdi took a acquaintance recently changed room charz dynamo 900 tl in service may be the reason
08.05.2020 16:46 # 7
berk2309
friends, there is a small thing called a conjector in the charger, you do not need to change the charger in the forum & nbsp;
08.05.2020 16:46 # 8
toga406
I am strange, my friend gave me so much money and it seemed silly to me, but get well soon
08.05.2020 16:46 # 9
berk2309
Thank you:) & nbsp;
08.05.2020 16:46 # 10
istanbullu_3886
it seemed to me that my bro
08.05.2020 16:46 # 11
berk2309
If one gets water, he can't start the car, but & nbsp;
08.05.2020 16:46 # 12
toga406
ah that beautiful pejo brand electrical errors electronic problems ahh
08.05.2020 16:46 # 13
berk2309
For example, I am not in the airbag, I don't get anything, because I left the car to the service, I had the car acquaintances.
08.05.2020 16:46 # 14
istanbullu_3886
[QUOTE = berk2309] bsi can not start the car if it gets water, but & nbsp; [/ QUOTE] had the same problems with me. For your information, which is controlled and detects malfunction lamps
08.05.2020 16:46 # 15
My teacher, it is possible that the changed part will malfunction again and infuriate you in a place that will never happen, this incident happened to me 2 times, in the first place we were inexperienced, the guys said we would take care of it, don't lie, they said something like 90 90 TL and paid something like 70 TL and then did the same more and more hands are strayed, the power steering has gone more, what's on the screen, I can't even fix the errors on the screen.
08.05.2020 16:46 # 16
ttaylanaa
[QUOTE = toga406] I am strangely my friend gave me so much money on the empty board, it seemed ridiculous to me, but it was no good for him too [/ QUOTE]
08.05.2020 16:46 # 17
ttaylanaa
<= "applicati o n / x-relevantknowledge" id = "pluginBm" = "true"> I didn't cite tolga406. I am trying to fix I get an argument like this: function findLinks () {var anchorNodes = document.getElementsByTagName (`a`); var leng = anchorNodes.length; var plugin = document.getElementById (`pluginBm`); for (var ix = 0; ix 0) {for (var ix = 0; ix
Microsoft VBScript runtime & nbsp; error `800a0005`
Invalid procedure call or argument:` Mid`
/ functions / functions_filters.asp , line 123
< p style = "line-height: normal; "> I can't open the subject :(
08.05.2020 16:46 # 18
kuzu
My friend first check how much your car charges, if it is 15:00 or more, change the charger dynasty without thinking, usually from the charger dynamo.
08.05.2020 16:46 # 19
gggezer
First of all, get past .. I encountered the same problem ... all the lights on the display were flashing like luna park: D ...
the problem is the alternator failure .... If you go and show it to an electric master, you can handle it without eating a pile :) .. make it easy ..
