Everything about 208 is here
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
08.05.2020 19:12 # 1
gokcenbg
I would like to share some useful information with you about 208..first you know that even though the exterior of the psa group vehicles is different, the internal engine and many parts fit the psa vehicles in the same segment .. the cruise control arm can be applied later. It will be sufficient if only the brake and clutch customers of the arm are suitable and this feature is activated in the vehicle.
In 208 base models, even though there is no speaker on the back doors, the whole installation is ready. When you insert the original speaker in the service, it is enough to code the tape with the service device.
In the 208s, there is a button that can be pressed in the place where the signal lever is. It provides an active deactivation in the daytime running lights. If you press this button while the vehicle is not working, you will hear an activity. Installation is towed. In the 2008, all headlight assembly is pulled in the bumper.
In all models without underfoot lighting in the 208s, the assembly is ready, you only need to get the lamps from the particle or service with the code of the full vehicle.
In models without torpedo lighting, there is a cover for lighting on the left side.
Auto child lock and vehicle alarm system purchased as an extra equipment in 208s are available as utilities. As far as I can see, the original alarm center is connected to the lock, there is no impact sensor and the alarm is connected to the horn. Activating the central alarm with ..
It is supposed to be absent, but all models have intermittent wipers, but the speed of over 100 km increases, it is obvious that it can be coded with the service device.
The telekinetic mirror can be integrated into all 208, but it costs a lot.
The 208 meg s screen can be applied to empty vehicles, even if the service does not support at all, I went on the job.
The only reason you have a hard night or not passing back gear is the lack of synchromesh in the vehicle.
At the bottom there are idle cables that I do not know what it works for but I think there is an esp device in vehicles that I don't think is esp. If the angle meter is present on the steering wheel, it looks at the esp key and the brain. If I have to turn on the headlights and have a corner lighting function, I will understand after that because this system works with the protractor in the original.
In empty models without a map reading lamp in 208s, the fitting of the lamps is ready.
Do not assume that there is no heating in the rearview mirrors. When you activate the rear window defroster, if the mirrors are electrical, there is also a resistance feature service booklet says so.
The fog lights of citro c3 picasso c3 pug 207 (round model) 301 c elyssee are as 208 e fog lights.
For chrome door handles, pug 207 307 407 citro c3 has chrome handles.
Again, the chrome glass strip of the new case c3 sits exactly on 208.
Friends without daytime running lights can have the original daytime running lights like peanuts without taking the daytime running light of elo and burning the parks.
For now, I have written what I have discovered and what I have discovered, I hope it works for you ... and if you equip the subject with your discovery and information, we can be more light to our 208s ... Büyükgövez
08.05.2020 19:12 # 2
okan77
Thanks for the sharing ... 208 alloy came ... :)
08.05.2020 19:12 # 3
emre_208
Greetings .. I have joined the Peugeot family now. 208 1.2 VTI
08.05.2020 19:12 # 4
GokhaN
[QUOTE = gokcenbg] I would like to share some useful information with you about 208..first you know that even if the exterior of the psa group vehicles is different, the internal component engine and many parts fit the psa vehicles in the same segment. It doesn't matter if it is a pug or a handle, only the brake and clutch customers are suitable and it will be sufficient to activate this feature in the vehicle.
For now, I have written what I have discovered and what I have discovered, I hope it works for you ... and if you equip the subject with your discovery and knowledge, we can be more light about our 208s ... I would like to thank you for your reading and reading ... Nice when you share a forum ... Büyükgövez [/ QUOTE]
Thanks for the information, most of them are known but it was very useful to collect them in a single title.
08.05.2020 19:12 # 5
GokhaN
[QUOTE = emre_208] greetings .. I have joined the Peugeot family now. 208 1.2 VTI [/ QUOTE]
good luck welcome
08.05.2020 19:12 # 6
emre_208
Thank you. I have a question. Steering is a little small. If I don't know 320 mm wrong. It seemed a little slippery to me alone. I'm looking for the right steering wheel cover for him, but I couldn't find it.
