Error message on Trip Computer
08.05.2020 15:48 # 1
Adana_k
Friends, on my trip computer, an article called ANTIPOLLUTION FAULT appears.
08.05.2020 15:48 # 2
Do you have a complaint in the car's homeland?
Anti pollution fault is a very extensive error. You need to connect your most beautiful vehicle to the computer and determine which error caused the anti pollution fault.
08.05.2020 15:48 # 3
Adana_k
There is no problem with the problem. There is no reduction in traction or vibration in the engine. Everything is normal. There is only this article.
08.05.2020 15:48 # 4
[QUOTE = Adana_k] There is no problem in the problem. There is no reduction in traction or vibration in the engine. Everything is normal. Just this article. [/ QUOTE]
If I was at your place, I would still have a service scan the codes. Do not forget to save the error codes and share them with us.
Have you recently started your vehicle with a booster battery?
Koliva 2011-07-10 17:36:09
08.05.2020 15:48 # 5
Adana_k
Thanks. I'll go tomorrow.
08.05.2020 15:48 # 6
Saleeh
What is your vehicle model? If you write this information to the signature section from the Member Control Panel, your question will be answered more quickly. Respects
08.05.2020 15:48 # 7
Adana_k
My car model 2006 pejo 206 feline 1.4 hdi
08.05.2020 15:48 # 8
turkuaz55
[QUOTE = Adana_k] My car model is 2006 pejo 206 feline 1.4 hdi [/ QUOTE]
Is there a road computer in 206? (GPS)
08.05.2020 15:48 # 9
metin
If you share this information in the signature section, it will always appear and you will not have to ask you every time. but if you write here, we will only stay here if we have another problem, we will have to ask again.
I know it as an antipolition error as I pollute the air, so it may be related to the fuel and combustion system,
If the fuel air mixture is not smooth, it can be air filter catalyst fuel pump injector etc. It is better to intervene according to the error code.
08.05.2020 15:48 # 10
My text says what you need +1: DD
08.05.2020 15:48 # 11
Adana_k
I wrote the car features in the signature section.
08.05.2020 15:48 # 12
Adana_k
Yes, I have a trip computer in my car. I made it later by changing the screen. It was very nice.
08.05.2020 15:48 # 13
Adana_k
As of today, the malfunction has improved on its own. I don't know what happens next.
08.05.2020 15:48 # 14
[QUOTE = Adana_k] As of today, the fault situation has recovered by itself. Then I don't know what happens. [/ QUOTE]
So I think it was due to the fuel you bought. Have you been to Ceyrek warehouse recently? Or did you buy cheap fuel?
08.05.2020 15:48 # 15
Adana_k
Yes, I went under a quarter tank, but I get extra diesel from fuel oil.
08.05.2020 15:48 # 16
[QUOTE = Adana_k] Yes, I went under a quarter tank, but I get extra diesel from fuel bp. [/ QUOTE]
Then the dirt on the bottom of the tank may have been caused. Get past it.
08.05.2020 15:48 # 17
Adana_k
My car is in 195000 km. I suspect Catalytic convector. Could it be full?
08.05.2020 15:48 # 18
[QUOTE = Adana_k] My car is 195000 km. I suspect Catalytic convector. Could it be full? [/ QUOTE]
If the catalytic converter is blocked:
1. Motor power duser,
2. The vehicle reacts at night in case of sudden acceleration,
3. When the bay is coming out, the vehicle wants lower gear, its power decreases gradually,
Are there any?
08.05.2020 15:48 # 19
Adana_k
No, nothing happened.
08.05.2020 15:48 # 20
Adana_k
Koliva brother, I have a request from you. My car shows the right door open from time to time on my way on the road. I opened the door.
Page : / 2
