ERROR CODES (Information)
08.05.2020 20:23 # 1
CemDemiral
QUOTE! .. Peugeot Fault Codes and Meanings P0101 BOILER AIR FLOW CIRCUIT BORDER / PERFORMANCE PROBLEM P0102 MAF CIRCUIT LOW INPUT P0103 MAF CIRCUIT HIGH INPUT P0104 MAF CIRCUIT RANGE P0105 MAP / BP CIRCUIT PREAM PREVENTION BP SENSOR LOW INPUT P0108 MAP / BP SENSOR HIGH INPUT P0109 MAP / BP CIRCUIT BREAKS P0110 IAT CIRCUIT Failure P0111 IAT CIRCUIT CIRCUIT PREPARATIVE / PERFORMANCE PROBLEM P0117 ECT CIRCUIT LOW INPUT P0118 ECT CIRCUIT HIGH INPUT P0119 ECT CIRCUIT RANGE P0120 TP SENSOR A CIRCULAR PREVENT P0121 TP SENSOR A LIMIT SENSOR AO PENSOR P0 SENSOR -06-02 11:01:05
08.05.2020 20:23 # 2
CemDemiral
P0125 CLOSED CIRCUIT FUEL CONTROL INSUFFICIENT COOLANT LIQUID TEMPERATURE P0126 CONSTANT RUNNING INFICIENT COOLING FLUID P0130 HEATING OIL PENSOR 1 IN 1 (SENSOR 1) 02 SENSOR CIRCUIT HIGH VOLTAGE (BANK 1, SENSOR 1) P0133 HEATED 02 SENSOR CIRCUIT SLOW RESPONSE (BANK 1, SENSOR 1) P0134 HEATED 02 SENSOR CIRCUIT (INFRARED) (0) 1, SENSOR 1) P0136 HEATED 02 SENSOR CIRCUIT FAILURE (BANK 1, SENSOR 2) P0137 HEATED 02 SENSOR CIRCUIT LOW VOLTAGE (BANK 1, SENSOR 2) P0138 HEATED 02 SENSOR CIRCUITS HIGH VOLTAGE 2 (SENSOR CIRCUITS 2) CIRCUIT SLOW RESPONSE (BANK 1, SENSOR 2) P0140 HEATED 02 SENSOR CIRCUIT MOBILITY DETECTED (BANK 1, SENSOR 2) P0141 HEATED 02 SENSOR HEATER CIRCUIT (BANK 1, SENSOR 2) VRESI FAILURE (BANK 1, SENSOR 3) P0143 HEATED 02 SENSOR CIRCUIT LOW VOLTAGE (BANK 1, SENSOR 3) P0144 HEATED 02 SENSOR CIRCUIT HIGH VOLTAGE (BANK 1, SENSOR 3) P0145 HEATER 1 SENSOR CIRCUIT (SENSOR 3) P0146 HEATED 02 SENSOR CIRCUIT MOBILITY NOT DETERMINED (BANK 1, SENSOR 3) P0147 HEATED 02 SENSOR HEATER CIRCUIT 02 SENSOR CIRCUIT 2, SENSOR CIRCUIT 2, SENSOR CIRCUIT (2 BANK) (BANK 2, SENSOR 1) P0152 HEATED 02 SENSOR CIRCUIT HIGH VOLTAGE (BANK 2, SENSOR 1) P0153 HEATED 02 SENSOR CIRCUIT SLOW RESPONSE (BANK 2, SENSOR 1) P0154 HEATER 2 SENSOR CIRCUIT BOTTLE SENSOR CIRCUIT (BANK 2) P0155 HEATED 02 SENSOR HEATER CIRCUIT Malfunction (BANK 2, SENSOR 1) P0156 HEATED 02 SENSOR CIRCUIT FAILURE (BANK 2, SENSOR 1) P0157 HEATED 02 SENSOR CIRCUIT VOLTAGE (BANK 2, SENSOR 2) 2, SENSOR 2) P0159 HEATED 0 2 SENSOR CIRCUIT SLOW REACTION (BANK 2, SENSOR 2) P0160 HEATED 02 SENSOR CIRCUIT MOBILITY DETECTED (BANK 2, SENSOR 2) P0161 HEATED 02 SENSOR HEATER CIRCUIT (BANK 2) SYSTEM VERY LOW (BANK 1) P0172 SYSTEM VERY RICH (BANK 1) P0173 FUEL ADJUSTMENT FAILURE (BANK 2) P0174 SYSTEM VERY LOW (BANK 2) P0175 SYSTEM SYSTEM VERY RICH (BANK 2) P0176 FUEL BLANK SENSOR CIRCUIT SENSOR CIRCUIT lIMIT / PERFORMANCE P0178 FUEL KARISE SENSOR circuit lOW input P0179 FUEL KARISE SENSOR circuit High input P0180 FUEL TEMPERATURE SENSOR circuit FAULT P0181 FUEL TEMPERATURE SENSOR circuit lIMIT / PERFORMANCE P0182 FUEL TEMPERATURE SENSOR circuit lOW input P0183 FUEL TEMPERATURE SENSOR circuit HIGH access P0184 FUEL HEAT SENSOR A CIRCUIT RANGES
08.05.2020 20:23 # 3
CemDemiral
P0185 FUEL TEMPERATURE SENSOR B circuit FAULT P0186 FUEL TEMPERATURE SENSOR B circuit LIMIT / PERFORMANCE FAILURE P0187 FUEL TEMPERATURE SENSOR B Circuit Low Input P0188 FUEL TEMPERATURE SENSOR B Circuit High Input P0189 FUEL TEMPERATURE SENSOR B circuit RANGE P0190 FUEL LINE PRESSURE SENSOR CIRCUIT FAILURE P0191 FUEL LINE PRESSURE SENSOR CIRCUIT BORDER / PERFORMANCE P0192 FUEL LINE PRESSURE SENSOR CIRCUIT HIGH INPUT P0193 FUEL LINE PRESSURE SENSOR CIRCUIT HIGH INPUT P0195 ENGINE OIL HEATING SENSOR CIRCUIT P0196 MOTOR PIPE SENSOR CIRCULATOR ENGINE OIL TEMPERATURE SENSOR INTERVALS P0200 injector circuit malfunction P0201 iNJECTOR CIRCUIT FAULT-cylinder # 1 P0202 iNJECTOR CIRCUIT FAULT-cylinder # 2 P0203 iNJECTOR CIRCUIT FAULT-cylinder # 3 P0204 iNJECTOR CIRCUIT FAULT-cylinder # 4 P0205 iNJECTOR CIRCUIT FAULT-cylinder # 5 P0206 INJECTOR CIRCUIT Malfunction - CYLINDER # 6 P0207 INJECTOR CIRCUIT Malfunction - CYLINDER # 7 P0208 INJECTOR CIRCUIT Malfunction-CYLINDER iR # 8 P0209 INJECTOR CIRCUIT Malfunction-CYLINDER # 10 P0211 INJECTOR CIRCUIT Malfunction-CYLINDER # 11 P0212 INJECTOR CIRCUIT CABLE Malfunction # 11 P0212 INJECTOR PIRE INTERFACE # 2 PIZE PIRO INTERFACE MOTOR STOP SOLENOID FAULT P0216 INJECTION TIMING CONTROL CIRCUIT FAILURE P0217 MOTOR OVER POWER STATUS P0218 TRANSMISSION OVER POWER STATUS P0219 MOTOR OVER SPEED PON2 PASS GAS / PEDAL SENSOR DOME PONES sensor B circuit low input P0223 GAS location sensor B circuit High input P0224 GAS location sensor B INTERVALS P0225 GAS location sensor C circuit failure P0227 GAS location sensor C circuit low input P0228 GAS location sensor C circuit High input P0229 GAS location sensor C INTERVALS P0230 FUEL PUMP FIRST CIRCUIT Malfunction P0231 FUEL PUMP SECONDARY CIRCUIT LOW P0232 FUEL PUMP SECOND CIRCUIT HIGH P0233 FUEL PUMP SECONDARY CIRCUIT RANGES P0234 ENGINE MORE OPERATING STATUS P0235 TURBO CHARGE SUPPORT SENSOR A CIRCUIT Malfunction P0236 TURBO CHARGE SUPPORT SENSOR A PERFORMANCE
08.05.2020 20:23 # 4
CemDemiral
P0237 TURBO CHARGER SUPPORT SENSOR A CIRCUIT P0238 TURBO CHARGER SUPPORT SENSOR A CIRCUIT HIGH P0239 TURBO CHARGER SUPPORT SENSOR B CIRCUIT Malfunction P0241 TURBO CHARGER SUPPORT SIGNAL RESTORATION P0243 WASTE DOOR solenoid defective P0244 WASTE DOOR solenoid LIMIT / Performance P0245 WASTE DOOR solenoid low P0246 WASTE DOOR solenoid high P0247 WASTE DOOR solenoid B DEFECTIVE P0248 WASTE DOOR solenoid B limits / Performance P0249 WASTE GATE solenoid B low P0250 WASTE GATE solenoid B hIGH P0251 injection pump Fuel XC CONTROL FAULT P0252 injection pump Fuel XC CONTROL BORDER / Performance P0253 injection Pump FUEL MEASUREMENT CONTROL oF lOW P0254 injection PUMP FUEL MEASUREMENT CONTROL oF hIGH P0255 injection pump Fuel XC CONTROL RANGE the P0256 injection pump Fuel XC CONTROL Malfunction B P0257 INJECTION PUMP FUEL FRIEND CONTROL B LIMIT / PERFORMANCE
08.05.2020 20:23 # 5
CemDemiral
P0286 injector circuit High-cylinder # 9 P0287 cylinder # 9 BALANCING ERROR P0288 INJECTOR Circuit Low-cylinder # 10 P0289 injector circuit High-cylinders # 10 P0290 cylinder # 10 BALANCING ERROR P0291 INJECTOR Circuit Low-cylinder # 11 p0292 injector circuit High-roller # 11 P0293 cylinder # 11 BALANCING ERROR P0294 iNJECTOR circuit low-cylinder # 12 P0295 injector circuit High-cylinders # 12 P0296 cylinder # 12 BALANCING ERROR P0300 INTERMITTENT IGNITION error was detected P0301 cylinder # 1 IGNITION error was detected P0302 cylinder # 2 IGNITION ERROR was determined P0303 cylinder # 3 IGNITION error was detected P0304 cylinder # 4 IGNITION error was detected P0305 cylinder # 5 IGNITION error was detected P0306 cylinder # 6 IGNITION error was detected P0307 cylinder # 7 IGNITION error was detected P0308 cylinder # 8 IGNITION error was detected P0309 CYLINDER # 9 IGNITION ERROR DETECTED P0310 CYLINDER # 10 IGNITION ERROR DETECTED P0311 CYLINDER # 11 IGNITION ERROR Was determined P0312 cylinder # 12 IGNITION error was detected P0320 IGNITION ENGINE SPEED INPUT CIRCUIT FAULT P0321 IGNITION ENGINE SPEED INPUT CIRCUIT LIMITS / Performance P0322 IGNITION ENGINE SPEED INPUT CIRCUIT NO SIGNAL P0323 IGNITION ENGINE SPEED INPUT CIRCUIT RANGE P0325 knock sensor 1 circuit malfunction P0326 Knock Sensor 1 CIRCUIT BORDER / PERFORMANCE P0327 HIT SENSOR 1 CIRCUIT LOW INPUT P0328 HIT SENSOR 1 CIRCUIT HIGH INPUT P0329 HIT SENSOR 1 CIRCUIT RANGE P0330 VURU WIRE SENSOR 2 WIRE PENSOR 2 CIRCUIT HIGH INPUT P0334 HIT SENSOR 2 CIRCUIT RANGES P0335 CRANK SHAFT FLOOR SENSOR A CIRCUIT FAILURE P0336 CRANK SHAFT FLOOR SENSOR A CIRCUIT CIRCUIT PREVENTION CIRCUIT A-RANGES P0340 CAM SPINDLE FLOOR SENSOR CIRCUIT FAILURE P0341 CAM M yl LOCATION SENSOR Circuit Performance P0342 camshaft ground sensor circuit low input P0343 camshaft ground sensor circuit High input P0344 camshaft ground sensor circuit INTERVALS P0350 lighting coil primary / secondary circuit malfunction P0351 lighting coil primary A / secondary circuit fault
08.05.2020 20:23 # 6
CemDemiral
Download More ...
http://dosya.co/i7i0mxkreluv/ Error_Codes _Continue .... docx.html
cemdemiral 2017-06-02 11:25:15
08.05.2020 20:23 # 7
health cem in your hands Thumbs Up
08.05.2020 20:23 # 8
CemDemiral
[QUOTE = sonerkyl] health cem into your hands Thumbs Up [/ QUOTE]
My brother is constantly asked, at least I wanted to know what happened :)
08.05.2020 20:23 # 9
KILIC
There are very few people looking at past issues, you can be sure to ask again :)
08.05.2020 20:23 # 10
doganatak
[QUOTE = CemDemiral] Download More ...
Health for your labor Link get information not working
08.05.2020 20:23 # 11
LUDACRIS
There is a nice application called obd2 auto malfunction codes in the play store.
08.05.2020 20:23 # 12
CemDemiral
[QUOTE = doganatak] [QUOTE = CemDemiral] Download More ...
Link Updated ..
08.05.2020 20:23 # 13
CemDemiral
[QUOTE = KILIÇ] There are very few people looking at past issues, you can be sure to ask again:) [/ QUOTE]
Hope there is nothing for the poor to make the bread :)
08.05.2020 20:23 # 14
doganatak
[QUOTE = CemDemiral] [QUOTE = doganatak] [QUOTE = CemDemiral] Download More ...
Link Updated ..
Thanks I downloaded Thumbs Up
