Error codes
08.05.2020 21:27 # 1
celik86
First of all, I just joined you hello. Yesterday I bought the 2008 model 407 executive package. In the exper report, p1614, p0299 and 5ff codes were detected. But such error codes were not written on the screen. I traveled 400 km on the day I bought it, it didn't write any error code. The reason I asked you for help is how important these codes are. The effect on the vehicle was overwhelming. What action do I need to take to fix it. I would be very happy if you answer. celik86 2020-02-05 18:33:32
08.05.2020 21:27 # 2
FatihBall
Welcome
P1614: Have air mass pressure failure sensors checked
P0299: Low turbo pressure
5ff: Generally a brain malfunction but can trigger many malfunctions, starstop may not work etc.
What I know was vw scirocco, golf, polo in my 3 vehicles before, I bought peugeout for the first time, but I was relatives with the brain-busters and electronics.
08.05.2020 21:27 # 3
celik86
Sir, thank you very much for your answer. Would it be too costly to fix these errors. For example, my turbocharger will change or my brain will change. Could you enlighten these issues, hodja. Thank you very much in advance.
08.05.2020 21:27 # 4
First of all, welcome to us. First of all, delete the malfunction codes. If it repeats, let us show a way accordingly. Now don't waste money, if the same error codes repeat then let's try to help.
08.05.2020 21:27 # 5
FatihBall
I agree with the soner +1, but if you are in the corner of your mind, if the turbo hoses have cracks, crushes, breaks, it is not a very important thing.
08.05.2020 21:27 # 6
celik86
Thank you all so much I had a lot of trouble. I will inform you about the developments. If I learn something new, I will present it to you as a information.
08.05.2020 21:27 # 7
cenkayclk
Hi guys, I'm with you with 407 2.0 hdi. There will be a few problems for you. While I was on the road today, my car suddenly lost its performance, as if the turbo was disabled, I slowed down and gasped again, it did not go as before. I connected the obd device, the turbo has pressure, it comes after 3 thousand cycles. The vehicle did not malfunction, but when I look at it with obd, it gives two fault codes (p1597 and p1351). What do you think is the problem?
