error after tape change
08.05.2020 18:47 # 1
LeckenJugend
Friends, I removed the clarion brand original tape on my 206+ vehicle and got a pioneer tape. now on my single screen, it says "front" in the middle and "13:47" on the right. is this normal? Should it be a black screen or should the clock be left blank?
08.05.2020 18:47 # 2
Alicilik
Stop the vehicle.
Turn off the tape,
Open the hood and the driver's window.
Lock the vehicle.
Wait for 3 minutes.
remove the pole head
Wait 1min
Install the pole head.
Wait 1 min.
Turn on the parking lamp without opening the door.
The problem will be fixed. When you open and close the door before it is corrected, that article changes.
08.05.2020 18:47 # 3
LeckenJugend
What will change if I do what you say? Will there be a playlist or something else on the screen? When I started the car in the morning, it was black screen and clock on the right. The "preliminary" text was gone.
08.05.2020 18:47 # 4
aokaymaz
[QUOTE = Receiving] Stop the vehicle.
Turn off the tape,
Lock the vehicle.
Wait for 3 minutes.
Wait 1min
Wait 1 min.
Ali, it was like a doctor's prescription, but hopefully your friend's problem has been solved.
08.05.2020 18:47 # 5
206+bulent
What did you do Ali: D
08.05.2020 18:47 # 6
okaNStarss
[QUOTE = LeckenJugend] What will change if I do what you said? Will there be a playlist or something else on the screen? When I started the car in the morning, it was black screen and clock on the right. The "preliminary" text was gone. [/ QUOTE]
no, only the date writer appears on the original tapes on the screen.
08.05.2020 18:47 # 7
Alicilik
When you open the doors after changing the tape, the door letter that remains open remains at some point while it slides, until you open and close the door again. This is the friend's situation, but I did not understand what else he was looking for, I wrote what he should do above. Some write that I can not find an answer, and some write it down.
08.05.2020 18:47 # 8
okaNStarss
[QUOTE = Recipient] When you open the doors after changing the tape, the door text that remains open stays at some point while the door remains closed until you open and close the door again. This is the friend's situation, but I did not understand what else he was looking for, I wrote what he should do above. Some write that I can not find an answer, and some write it down.
Exactly, Ali Sister :)
08.05.2020 18:47 # 9
LeckenJugend
What I wanted to learn was just what the normal is and what happens when I do this, but I had not guessed it would be so angry. If I had an extreme reaction, forgive Ali brother.
08.05.2020 18:47 # 10
Alicilik
I'm someone who says a little language, I'm not angry. You just learn the vehicle, I learned most things months later. Maybe he still has a lot I don't know.
I solved the tape problem with a 3-line display and then I learned this method. I wrote in many titles, you can actually see it in the sound system section.
Whenever you make any changes to the vehicle, follow the event I mentioned.
08.05.2020 18:47 # 11
DgNTsN
Turn off the tape,
Lock the vehicle.
Wait for 3 minutes.
Wait 1min
Wait 1 min.
Peugeot is a vehicle that is in communication with everywhere like a robot. The friend explained the solution very well. When a track or electronic part is removed from the vehicle with the sensor, the vehicle needs to be reset. He does this in the things described above. In this way, the vehicle brain leaves that device and does not get confused.
