Era of misalignment ...
08.05.2020 19:28 # 1
Adem Kurtuldu
2006 1.4hdi 206 vehicles on the way to the gas when it is loaded, for example, from 2000 to 4000, it falls down and connects to the pc.
08.05.2020 19:28 # 2
samet206
If there is no other problem. It is most likely that the pressure will change to the pad, the vehicle is jumping. I went to the service, I was not wrong, the problem was under pressure.
samet206 2015-10-19 01:19:43
08.05.2020 19:28 # 3
debug
As the friend says, the pressure will probably change the pad
08.05.2020 19:28 # 4
Adem Kurtuldu
But wouldn't the master who looked at the turbo pressure injector feel the touring pad if it changed the pad?
08.05.2020 19:28 # 5
debug
Maybe it didn't matter. He says it looks like pressure, but it is useful to show it. In the forum, you can look at a clutch control topic and apply it yourself. At least he gives an idea.
08.05.2020 19:28 # 6
samet206
It may not have been understood. I am not talking precisely anyway. If I look at the car, it is not possible to understand it from here. It may be in a different problem. how are the gears? Look at them. In other ways, you think that you wouldn't feel like touring with a master vehicle. But you are already opening this subject because the master cannot find a solution to your problem.
08.05.2020 19:28 # 7
Adem Kurtuldu
The grip is the same with normal speed, but it does this only at 3 speeds at 1-2 gears, or when it suddenly loads it, I'm not entirely sure either, but the grip is OK
08.05.2020 19:28 # 8
samet206
The clutch was problem-free in the same way. There was no problem in acceleration in the same way. It only started to shift gears, the room was the last time I went to the mechanic. It would do in all gears since it would do 1-2-3 alone, no matter what gear ...
08.05.2020 19:28 # 9
Adem Kurtuldu
Exactly, I want it, but is there any problem in the near future?
08.05.2020 19:28 # 10
samet206
Hodja problem, trouble, if anything else, I do not know about it, you have to look at the master again. If the piece I said is damaged, it is troubled. But first of all, a person who sees a person can see the vehicle, maybe there is something else that is simple.
08.05.2020 19:28 # 11
Adem Kurtuldu
[QUOTE = samet206] Teacher, if the problem is something else, I do not know it, you have to look at the master again. I do not recommend it or even have it done as soon as possible. If the piece I say is damaged, it is troublesome.
[/ QUOTE] First of all, thank you for your interest, as you said brother, I show the vehicle in detail.
08.05.2020 19:28 # 12
Adem Kurtuldu
Just like you said, we started the printing well and changed it. Valeo brand was installed. They are made of 1.6hdi c4 with sheet metal rim. But what happened to my mind was the print brand that came out, was it an oem product or a room ??
