Enlarge tire size. . .
08.05.2020 16:21 # 1
Onurb
Guys, I need your help on something. . . My Tire size 205/40/17 I am not satisfied with the tire's thinness, I want to make 205/45/17. Will rubber rub this thickness make? My vehicle is 206 Plus. . . Member
08.05.2020 16:21 # 2
Brother I still use 175/65/14 rubbing it when two doubles back to back yours good courage. The appearance of 17 is good, but if you want to do 206 both sporty and comfortable, you will do 195/50/16, this is an intermediate value. thickens the cheek, if you reduce the rim, you will gain comfort and loss of appearance. If you enlarge the rim and enlarge the rim, you will get the appearance of comfort.
If a friend can measure the size of the tires on the autocad and find something similar to him or you do it yourself, it will be healthier. & nbsp; & Nbsp;
08.05.2020 16:21 # 3
gravis_pro
I made the dimensions of the tires I bought in this link in Autocad.
& nbsp ;
I drew in Autocad according to the dimensions in the question. The result is that the tire of the
205/40/17 tire should have a diameter of 595.8 mm, and the tire diameter of 205/45/17 you want to install is 616.3 mm. I guess you can measure from here. I hope it works.
gravis_pro 2011-11-13 23:01:04
08.05.2020 16:21 # 4
[QUOTE = gravis_pro]
& nbsp ;
Absolutely ... "Laugh" Reviews
08.05.2020 16:21 # 5
205 55 16 will be the same size as your tire but a new rim is a must
