Engine Water Auction and White Smoke
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 17:22 # 1
altug_19
Hello friends,
I'm using 406 coupe 1999 model 3.0 vehicle. White smoke comes out of my vehicle's exhaust. In the winter months, a very dense smoke output is observed with its effect. There is also a lack of engine water in my car or something. The engine water light is on, I am completing the water again. It turns on again after 1-1.5 months how much water it corresponds to .. now I have it checked for leakage and I think there is no water leakage in the vehicle and it gives this water into the cylinder or makes a leak from the top cover gasket. I expect help from more knowledgeable friends in the same way or on the subject. I live in Ankara and I would like to show them if you have a master you can recommend ..
08.05.2020 17:22 # 2
Serkan
Sir, have you pulled the oil dipstick and checked it, do you have any water? What you say is like signs of seal burn
08.05.2020 17:22 # 3
istanbullu_3886
Yaga may not mix your problem in me because the gasket burned exos part is burnt, the water is dropping from the exos the same thing came to my press
08.05.2020 17:22 # 4
altug_19
Since the vehicle is a V6 engine, I have a logic that I have reached with a double cylinder head, which is why I am wrong when compared to normal vehicles that it will be about twice the cost? I was wondering how can antifreeze come out of the exhaust since I cannot visualize it in my eyes? What exactly does this mean if the top cap gasket is burnt out? If I drive this way, what risk do I take until it is repaired? I would be very glad if you can help ..
08.05.2020 17:22 # 5
altug_19
Meanwhile, I check the oil, no water mixing.
08.05.2020 17:22 # 6
Serkan
Sir, if the gasket is burnt, the cooling water enters the combustion chambers, it is discharged from the exhaust in the form of steam and droplets from here, as the water is mixed with the engine oil, it loses its oil fluidity and lubrication feature.
