engine water
08.05.2020 15:35 # 1
metin
Did the heating system look over there, is it supplying water into the vehicle?
08.05.2020 15:35 # 2
cerci07
There is a place in the bottom, take a good look below, right, left and right.
08.05.2020 15:35 # 3
[QUOTE = ezelefe] Friends would reduce the engine water of my car.
I completed it 2 days ago, the water is out of water, there is no leg etc. is hungry can I do it from her
< DIV>
& nbsp;
If the air conditioner is turned on, you need to feed the air conditioner first "
If the water decreases, I will say that it is evaporating, and if its cover is closed, it cannot be evaporated that much. There is definitely a leak somewhere. If you get a new LPG or something, check your connections.
08.05.2020 15:35 # 4
tigerland
I think go to the master or have it checked by the service.
08.05.2020 15:35 # 5
Once on the bottom of the mats should be checked. Press firmly under the mats with your hand and check for wetness.
08.05.2020 15:35 # 6
muntehaozen
I am reflecting what the service tells me. There is a gap in the place to cool it from the piston. If I could not evaporate the water passing through the car, it would not ignore the engine water.
08.05.2020 15:35 # 7
eneslan
-Vaporation may occur due to hot weather. & Nbsp;
-If there is a leak in the heating radiator, it reduces the engine water. Check the flooring on the driver's side from time to time so that it is wet, not wet and smells of antifreeze in the vehicle. & Nbsp;
This is all my experience :)
08.05.2020 15:35 # 8
ose
They & nbsp; except you will lie down and look. & nbsp;
08.05.2020 15:35 # 9
MagicPerformance
I hope it's not from the radiator, they happened to me, they are removing the torpedo :(
08.05.2020 15:35 # 10
There is nothing to do with the air conditioner and the engine coolant ... Check the bottom of the vehicle well. Take a good look under the torpedo, under the mats, on the carpet, etc ...
08.05.2020 15:35 # 11
okan77
A terrible problem
