Engine transmission and esp failures
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
08.05.2020 21:19 # 1
Mudur
Hello friends
I opened this issue because I believe that you have the information that will help me. 2012 model 208 1.6 diesel car semi-automatic occasionally on the screen, the engine transmission is burning and protecting the malfunctions. There is no problem going in a thousand, but this shape is always annoying to open the hood, if you have annoying knowledge, please ask for help
08.05.2020 21:19 # 2
First of all, welcome, Hodja. Did you take your vehicle to the service and have the fault codes checked. One of the abs sensors may be faulty or it may cause this type of malfunction because it gets dirty. When the vehicle is cold, I say clean the places where the disc and pads are with pressure water.
08.05.2020 21:19 # 3
Mudur
Today I went to a skilled cerebellist, tied the vehicle, checked it and deleted it, now it will become clear when I do it again.
08.05.2020 21:19 # 4
Thanks for the return, I hope it will not be a problem again.
08.05.2020 21:19 # 5
kimiraikkonen
Well that's 208. So it does. Even those who study technically prefer trial and error.
08.05.2020 21:19 # 6
frknhacioglu
I have confirmed that the same fault happened to me despite the fact that it has passed over the subject.
When I connected the vehicle to the machine when it gave the fault codes, I saw that it was caused by the accelerator pedal. We cleared the faults and proceeded smoothly. It has been about 5 months and never again. My master said, let's not change it immediately, maybe it is an instant wired situation. It seems so :)
