Engine speed during 307 automatic gear shifts
08.05.2020 19:42 # 1
gngr
My automatic car 2004 enables gear shifting after 3000 cycles during the shift. Is the transition normal after this light gas sound?
My friend has a 2005 model, I didn't feel that much, so I ask. gngr 2016-03-07 21:47:56
08.05.2020 19:42 # 2
talip206
I did not understand the concept after gas noise, but the shift speed varies according to the rate of throttle, the slope of the road, the person in the vehicle and the load situation. while it changes at 2500 rpm, it is different on the light ramp.
If there is no knock in the gear shift, no error code, no abnormal reactions, no problem.
08.05.2020 19:42 # 3
gngr
Eyvan. The error is not in question, the friend came quietly, I said from him tsk.
08.05.2020 19:42 # 4
burakrak53
The reasons for the high gear shifting on straight road may be due to insufficient transmission oil of the vehicle and insufficient pressure. The other reason is that if you set off directly without the vehicle warming up, this usually happens in the cold mornings, because the transmission oil is not yet warm enough, the gear shifts at a higher speed since the pressure will be low. They do not have a problem, but if these conditions are seen in hot weather or at sufficient oil level, there may be situations such as solenoid problem, hydraulic block failure, oil leakage from seals, pressure drop, torque converter or pads. can cause. The character of al4 transmissions is a little different one day, different day, it takes some time to get used to different. If there is constantly over 3000 revs, I think there is a problem.
08.05.2020 19:42 # 5
gngr
There is not that much sound, normal manual vehicles have a little purring after 3000 cycles or it goes after that purring, of course this is not always.
