Engine Sound Changed
08.05.2020 18:48 # 1
SOP
Hello..
I have a 1.6 XT automatic 2004 model vehicle with LPG at 83000 Km. There was almost no sound from the engine. But a different voice started to sound for 1 month. It can be heard even while inside the vehicle. While the engine is running, this sound is heard serially as "truck tractor truck tractor truck", and the sound coming in is thinner.
I took it to the master, he said it might be a valve. I thought it was from the timing. It has just changed, it started to sound when driving 600km. I said I can't be from there. The master said it already comes from the engine.
Did anything happen to you? I'm a little nervous about a problem.
08.05.2020 18:48 # 2
muro_60
It can come from LPG injector, take it to the gas, try it.
08.05.2020 18:48 # 3
SOP
The same sound sounds in gasoline .. I think it's another source of sound
08.05.2020 18:48 # 4
muro_60
There are many reasons for this, if you share the video, we will help
08.05.2020 18:48 # 5
slhyldz
Engine cold - hot difference?
If the answer is yes, it makes sense to say that the master may be a subop. Sound is more pronounced when the engine is cold. If there is no difference, no comment.
And sound is not something to be understood in this way. Take it to another master who says it may be the best. My advice is to look when the engine is cold.
Note: It is normal for peugeot engines with LPG to go subopen.
Complete subop + reed + ignition coil + labor costs 1000 TL. (with original parts)
08.05.2020 18:48 # 6
SOP
Yeah it feels more obvious when it's cold. I think when I use it this way and when it sounds loud, I will have to go and pay it. Thanks
