|   | Engine Shake problem |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 207 | |
| 08.05.2020 21:04 | # 1 |
|  conteo | |
|   Let me get your comments about this situation, what do you think your friends might be?  | |
| 08.05.2020 21:04 | # 2 |
|  sonerkyl | |
teacher, there are two options, one is due to engine and transmission buckles, second one is to look at the printing flywheel.
| 08.05.2020 21:04 | # 3 |
|  GokhaN | |
I don't understand exactly what he is telling you right now, but engine shake is caused by wedges.
| 08.05.2020 21:04 | # 4 |
|  conteo | |
For example, how many thousand circuits do you press on your own vehicle in 2 and 3 gears? There is no LPG in my car. It needs to be pressed easily for 4 5 thousand cycles. After 3 thousand, there is a tremor. So this tremor does not come from the steering wheel or the wheel.   I will see a master tomorrow.  | |
| 08.05.2020 21:04 | # 5 |
|  conteo | |
Friends, there is a situation like this, we tried idle, there is no tremor, only when accelerating in the gears. It is likely to be a flywheel in the press pad
