Engine shake at idle 307
08.05.2020 18:52 # 1
hatayli
friends, I do not know if such a subject has been opened before. my problem is this. I just bought my vehicle 1.6 HDI Premium 150 thousand. engine idling is also running a bit jerky. Tremor disappears when you start to move and move to 1st gear. When I change gear, I feel the vibration again when the tachometer reaches normal level. so just idling does it. I wonder what the problem might be.
08.05.2020 18:52 # 2
berk2309
If the vehicle is working unevenly, my teacher will have an operating noise, like a growling noise.
08.05.2020 18:52 # 3
hatayli
no work is fine, idling speed indicator is still steady, I connected it to the computer, there was no error in the injectors.
08.05.2020 18:52 # 4
mehmethannn
Hello, 7 months ago when I bought the car, it was fixed at idle, but there was a very slight tremor in only 7-8 seconds when the vehicle was idle. I never asked the master. I had the car maintained. timing set, and other general maintenance such as gasoline filter. trembling has gone. but i don't know why. I never asked the master when it got better.
08.05.2020 18:52 # 5
hatayli
I asked the master too, said the flywheel gear and the pressure pad should change. But you know, expensive parts in those parts. I don't know if I change it now or not. since the breakdown doesn't have to vibrate on those parts on the move?
08.05.2020 18:52 # 6
ucanturk
Actually, I couldn't understand what the problem with idling had to do with the pressure pad?
I have the same tremor that my friend Mehmet said, but I did not fall on it. oil and filters have changed but the situation is the same.
08.05.2020 18:52 # 7
samu
Sa friends have the same problem with me, spark plugs, coils changed, it happened again
08.05.2020 18:52 # 8
hatayli
I wonder if the spark plugs are broken, does this shock?
08.05.2020 18:52 # 9
fatihgg
I would like to have the pad checked.
08.05.2020 18:52 # 10
hatayli
It is necessary to stop by industry this weekend ...
08.05.2020 18:52 # 11
hatayli
actual
08.05.2020 18:52 # 12
Zzeskin
How many revolutions does your vehicle run at idle?
I think the possibilities are;
Idle Speed may be low
- Engine wedges may have lost their characteristics.
- Cleaning the injectors can also help
But I do not think it will be from the pressure pad or flywheel gear.
08.05.2020 18:52 # 13
hatayli
[QUOTE = Zzeskin] How fast is your vehicle running at idle?
my vehicle is running at idle 1-0.8 and there is absolutely no play.
injectors were maintained at the service last week, washers, screws etc. changed.
Then let me look at the engine chocks. because when it starts, the vehicle vibrates completely.
08.05.2020 18:52 # 14
seydisehirli
antipollition fault .... !!!!!! My 2005 307 vehicle gives this error, although I have deleted it a few times, it still has a solution. Could you help me friends?
08.05.2020 18:52 # 15
alitekeli35
HELLO HELLO I HAVE REPLACED THE IGNITION COIL AND SPARK PLUGS.
THERE ARE THOUSANDS OF PROBLEMS IN THE BAY I HAVE A GOOD MASTER IN IZMIR CUTTING THE SHAKE
KNOW IT TAKES 30 MINUTES
08.05.2020 18:52 # 16
alitekeli35
HI
antipollition fault ERROR GIVES 1 YEAR TO ME
IT WILL BE GENERATED AS MUCH AS YOU WANT
I HAVE READ AT LEAST 100 ARTICLES TO A PROBLEM OF THE COGU PEJOD DUE TO THE LPG INSTALLATION OF THIS VEHICLE.
THE FUEL OF THE VEHICLE IS SOURCE FROM THE AIR MIXED RICH
I ASKED 3 SEPARATE MASTERS, THE SAME LEVEL HAS BEEN SOLED.
NO DAMAGE TO THE ENGINE
IF THE VEHICLE IS DIESEL, SENSOR MAY ALSO CHANGE.
08.05.2020 18:52 # 17
seydisehirli
my brother with benzil lrg was about 3 months, the vehicle is on fire for 2 years.
08.05.2020 18:52 # 18
hatayli
[QUOTE = alitekeli35] FRIEND I HAVE CHANGED THE IGNITION COIL AND SPARK PLUGS.
thanks for your answer. I will do what you say exactly. already, the spark plugs in the vehicle do not work. let me change them and clean the throat butterfly. I hope the problem is solved.
08.05.2020 18:52 # 19
hatayli
yes friends problem solved. we changed the lower engine ear was torn. I am now driving my vehicle more enjoyably. I thank all the friends who are trying to help. and I want to thank the master who helped me here.
08.05.2020 18:52 # 20
Gorkem353535
Brother, is there a master's number in this Izmir
