engine or injector cleaner ...
08.05.2020 19:07 # 1
407 ERHAN
friends, my car is 1.6 hdi 407, there is no problem in my engine right now but i will make an average of 1000 km in the near future, i want to use injector cleaner additive on long road ? 407 ERHAN 2015-02-23 14:36:36
08.05.2020 19:07 # 2
baybaba
Frankly, I do not believe that such contributions are beneficial, I thought for a while, but
When I researched and read those who had problems, it seemed like looking for an adventure where we stopped,
08.05.2020 19:07 # 3
Alicilik
Use the products of proven companies with advice.
Wurth
Berner
etc
I saw a lot of people who used the additive without reading the instructions for use and thrown the substance. Before the additive maintenance, the full tank is thrown to the entire fog and the vehicle is used close to the end of the warehouse. With the change of filter and oil, the vehicle is revived even more. Meanwhile, it will be checked. The contribution put during maintenance is completely the sales policy.
Also let me see who has suffered from matter. I take Toyota to a service in 10 thousand. In every sense, they contribute to a fog. Is the big company not aware of the damage?
I recommend using it before a diesel filter in 30 thousand.
08.05.2020 19:07 # 4
407 ERHAN
thank you friends...
08.05.2020 19:07 # 5
okan77
I bought wurth brand in summer 307 1.6 16v. At 70000 km. I couldn't see a noticeable difference ...
it was necessary to use several warehouses. If it is going to be added directly to the warehouse ... I took a figure of 40 TL.
08.05.2020 19:07 # 6
407 ERHAN
I think the best and most reliable one is to remove the injectors and connect them to the injector cleaning device.
08.05.2020 19:07 # 7
Alicilik
I would definitely recommend it. Once the injector is broken, push it in. Once the diesel injector has been removed and played, you will be informed that it gets more gentle.
08.05.2020 19:07 # 8
407 ERHAN
I understand my friend, thank you very much for your warning.
08.05.2020 19:07 # 9
sezar206
Buy Wurth is not a problem. Of course it will be useful. I gave 40 TL to the small tube. I used it on gasoline. I put the tool with the scraper at idle, but the valve setting was not broken from it.
08.05.2020 19:07 # 10
407 ERHAN
I understood my friend Fatih, thank you.
