Engine oil temperature (help)
08.05.2020 16:49 # 1
herry
Hello friends, 2001 1.6 206 owner, I stayed in very busy traffic for about 1 hour, I did stop, step by step, the most right engine oil degree on the dial has passed 90 and I came to the line on it, I do not know if it is psychological, but I felt the smell of oil, then the road opened, I got my speed 15 dkya returned to normal 90. Do you think it's normal?
08.05.2020 16:49 # 2
206206
hi
is perfectly normal & nbsp; I & nbsp; long-term & nbsp; Stop & nbsp; up to & nbsp; & nbsp; tempreture & nbsp; 100 & nbsp; Approaching
When
takes over the vehicle cycle & nbsp; I fall is
08.05.2020 16:49 # 3
toga406
now you need to pay attention first. If the vehicle is 206, there is a temperature indicator or a second indicator oil temperature indicator. j
If the temperature is close to 100, it will be normal.
08.05.2020 16:49 # 4
toga406
put the picture of the dial on the site
08.05.2020 16:49 # 5
herry
[QUOTE = toga406] put the picture of the dial on the site [/ QUOTE]
my car 206 when you say I went to look at the car at this time I came to look at the dial, the indicator on the right is already an oil sign
08.05.2020 16:49 # 6
toga406
You say the oil sign, but remember, every vehicle has a temperature stick first, then 406 407 and some models have an oil temperature indicator. If I find the link I throw it right away wait
08.05.2020 16:49 # 7
toga406
http://f1203.hizliresim.com/v/s/3tjff. jpg
& nbsp; click this link or http://forum.peugeotturkey.com/forum_posts.asp?TID=22186&KW=toga406&title=406-motor-ya- Check the images available at the temperature-indicator-inquiry & nbsp; link. The indicator on the far right in the picture belongs to the oil temperature indicator with the oblique sign on the far left.
Now think and check according to your vehicle status
08.05.2020 16:49 # 8
zgr
[QUOTE = herry] Friends hi, 2001 1.6 206 owner, I stayed in very heavy traffic today, I stopped for about 1 hour, got up, step by step, the most right engine oil level on the dial has passed 90 and it came to the line on it, I don't know if it is psychological but I felt an oil smell after the road It was urgent, I took my speed and returned to normal for 15 minutes to 90. Do you think it's normal? [/ QUOTE] What is the model of the
tool? I have 2001 206 1.6 xt. on the instrument panel (from left to right) there is the petrol hand - cycle hand - speed hand and temperature hand (far right hand), this hand is not oil but water temperature hand. this is my car. I think it is probably yours.
The temperature gauge shows me 90 even in a traffic jam. If it is too tight, it is even close to red. After a while, I think the fan turns on, the needle drops visibly.
08.05.2020 16:49 # 9
EmSul
Either friends, herry's vehicle is at 206cc and we have the dial of our GTIs.
08.05.2020 16:49 # 10
SZKR
It is a very normal situation in stop-and-go traffic, as it is comfortable for you to check the oil level.
08.05.2020 16:49 # 11
herry
Thank you for your valuable answers.
08.05.2020 16:49 # 12
beveta
As he said in his friends, that dial is the oil indicator dial, the other is the temperature (engine water temperature) dial ... herry friend first of all, your thermostat is 89 thermostat in general, the fan is 2 stages in peugeot brand vehicles ... when the temperature exceeds 90 degrees, 1 stage fan between 92 94 turns on ... 2-stage fan can reach up to 100 degrees after 94 and after ... these normal cruises are especially in those days when the air temperature is affecting ... but it did not happen in my car before, which is generally present in all peugeot ... go and go to a master thermostat Let it pour 90 degrees boiled water into a container and shake it with its hand in the thermostat. ...
Reviews
08.05.2020 16:49 # 13
toga406
Both oil and heat indicators are available in the link I provided.
