engine oil selection
08.05.2020 16:47 # 1
206206
& Nbsp; & nbsp; & nbsp; & nbsp; Hello & nbsp; friends,
& nbsp; 206 hdi & nbsp; I use my vehicle at the authorized service & nbsp; I was taking it for maintenance. But special & nbsp; I'll take it to the master. & nbsp; & nbsp; Service & nbsp; so far & nbsp; I looked at the bills. 10/40 diesel & nbsp; engine oil used and 15 thousand km & nbsp; in a way & nbsp; I'm leaving. You & nbsp; I'll take the oil I want to learn & nbsp; I wonder to what extent I need to get fat and I will buy & nbsp; Oil & nbsp; how many thousand should I change. & nbsp; Thanks
08.05.2020 16:47 # 2
[Quote = 206206] & nbsp; & nbsp; & nbsp; & nbsp; Hello & nbsp; friends,
You can use 5W-40 fully synthetic oil of a quality brand. This Mobil 1 Super 3000 can also be Castrol Edge. In this case, the oil change will reach 15 thousand, but I usually change around 13 thousand. Usually around 3 liters of oil are changed, but this figure is variable. You buy 5 liters of oil and use it in the next change.
08.05.2020 16:47 # 3
ozi033
mobile is very good
08.05.2020 16:47 # 4
teoman_40
1.4 hdi 307 is the most suitable oil, how many is the number? I had put 10 -40, today a master said "work very noisy, change the oil or the engine will wrap, you can not get out of it". What do you think ?
08.05.2020 16:47 # 5
5w-40 is put in diesel vehicles. More beautifully, 5w-40 oil is produced for diesel production.
Gasoline vehicles are preferably 10w-40 or 5w-40. 5w-40 is fine oil, fully synthetic.
08.05.2020 16:47 # 6
teoman_40
When we put the 5 w40, does the engine run less loudly? Does the 10 w40 have any damage to the engine?
08.05.2020 16:47 # 7
I don't know the reason, I guess the turbo will work more efficiently and healthily in 5w-40s.
I know that 10w-40s cannot be put in diesel.
08.05.2020 16:47 # 8
sosyete_60
If the city you live in is very hard in winter, I would prefer you to use 0-40 because the car runs very easily in the morning, a little 0-40 oil is expensive, but between 5-40 and 10 TL, 15 TL is something that is suitable for diesel and gasoline or LPG vehicle. I'm making changes summer and winter mobile1 & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; I use 0-40 oil, I am very happy, besides, if you use borpower, it is perfect. Orginal Mobil1 is a very good quality oil.
08.05.2020 16:47 # 9
206206
Thank you very much to everyone who answered.
ideas occurred & nbsp; & nbsp; 5/40 & nbsp; I will use synthetic oil, but & nbsp; Service & nbsp; why & nbsp; both piling & nbsp; both in & nbsp; have put 10/40 on diesel engine for years & nbsp; so weird
08.05.2020 16:47 # 10
teoman_40
Is it interesting ...
08.05.2020 16:47 # 11
206206
5/40 oil number & nbsp; is it standard or & nbsp; diesel & nbsp; Gasoline & nbsp; Are you leaving? & nbsp;
08.05.2020 16:47 # 12
[QUOTE = 206206] 5/40 oil number & nbsp; is it standard or & nbsp; diesel & nbsp; Gasoline & nbsp; Are you leaving? & nbsp; [/ QUOTE]
We can say that it is standard, but some brands have special oils for diesel. For example Castrol Edge Turbo Diesel 5W-40 is also available Castrol Edge 5W-40. I think it is 5W-40 Esp Formula in Mobil 1. There is no diesel gasoline difference. Reviews
08.05.2020 16:47 # 13
teoman_40
I have 10-40 oil in my car right now. 3000 km from the village. Something happened. Should I change it, would it hurt?
08.05.2020 16:47 # 14
cerci07
[QUOTE = teoman_40] I have 10-40 oils in my car now. 3000 km from the village. Something happened. Should I change it, would it hurt? [/ QUOTE]
nothing happens you don't need to change
10w40 - 5w40 - 5w30 - 0w30 & nbsp; you can use whatever comes to your business
08.05.2020 16:47 # 15
206206
ELF 5W40 EXELLIUM 4LT ENGINE OIL bu & nbsp; oil & nbsp; How & nbsp; Does anyone use friends & nbsp; & nbsp;? I am not mistaken & nbsp; pegeout also recommends this. & nbsp; 55 tl & nbsp; to & nbsp; I found & nbsp; somewhere & nbsp;
08.05.2020 16:47 # 16
[QUOTE = 206206] ELF 5W40 EXELLIUM 4LT ENGINE OIL bu & nbsp; oil & nbsp; How & nbsp; Does anyone use friends & nbsp; & nbsp;? I am not mistaken & nbsp; pegeout also recommends this. & nbsp; 55 tl & nbsp; to & nbsp; I found & nbsp; somewhere & nbsp; [/ QUOTE]
I personally would have preferred Castrol after Mobil 1 first. Price separate "Smile"
08.05.2020 16:47 # 17
Cmoss06
If your car is not accustomed to 5/40, if your bads are bad, the engine will sweat excessively.
08.05.2020 16:47 # 18
EmSul
Friends, I was going to ask my car 206 GTI ... What oil should I use when changing the oil? Castrol edge 5w-40 & nbsp; (the owner of the UG 206, he said, was using Castrol edge 5w-40 at the time) & nbsp; It plays only 20 lira between the 2's at 4lt. What is the difference between them I wonder? What is the difference between 0w-40 and 5w-40? Other than Mobil and Castrol brand difference ... I think my previous oil was 5w-40 in elf ..
08.05.2020 16:47 # 19
Cmoss06
In thin oil, the engine runs more comfortably. In winter, especially in diesel vehicles, quality and 0 or 5 numbers are used. followed by W, which normally means winter. The first number represents the oil viscosity under low temperatures, as an indication of how the oil will flow in the winter season. The lower the first number, the thinner the oil at low temperatures.
The second number after
W represents the oil viscosity under high temperatures. The higher the number, the thicker the oil will be at higher temperatures. Using the right viscosity for your engine improves engine performance, reduces engine wear and improves fuel efficiency.
08.05.2020 16:47 # 20
Ert2005
friends hi peugeot partner 1.9 diesel 2006 model & nbsp; i have km 185000 2. hand bought 10000 maintenance came, i will not know which brand i will change the engine oil and i would not know 10-40 thanks thanks Ert2005 2018-07-14 06:21:02
