Engine oil reset
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 16:09 # 1
fexzi
I will change the engine oil, but how to reset the key sign on the indicator, I will be glad if you inform.
by the way, which oil should I use for 1.6 16v 307 XT? Thank you.
08.05.2020 16:09 # 2
change it then let me tell you. "Blink"
08.05.2020 16:09 # 3
mehmet eren
I think the master will have an elephant and you will not understand yourself.
08.05.2020 16:09 # 4
[QUOTE = fexzi]
by the way, which oil should I use for 1.6 16v 307 XT? what ? thanks.
The master will change the oil, and will do the reset. Of course, if you want to learn, there have been many times in the forum. You can use 5W-40 or 0W-40, as most of us use in the forum, considering that your vehicle is gasoline, its mileage is not excessive and you do not have a problem such as oil reduction. Reviews
08.05.2020 16:09 # 5
fexzi
I consulted because I was not able to be in my province, oil change and filter change completed with 0w-40.
I did it.
Procedure to Reset Peugeot & nbsp; Service Light as follows:
1. Switch the & nbsp; Ignition Off
2. Press and & nbsp; hold & nbsp; the & nbsp; tripmeter (mileage reset) & nbsp; button on the dash
3. Now switch the ignition to the ON position
4. Keep & nbsp; the button pressed for 10 seconds
5. The display will read `0` and the service symbol will extinguish. Job done.
08.05.2020 16:09 # 6
mobil 1 0-40
cem big brother
08.05.2020 16:09 # 7
mehmet eren
[QUOTE = berkekk] mobile 1 0-40
cem big brother
"Applause" "Applause" "Applause" "Applause"
"Applause"
08.05.2020 16:09 # 8
marad
Friends a few months ago I had to change the oil urgently.
I went to the nearest gas station, asked if the guy was lpg. When you say yes, you filled it with 15/40 (oil) shell. & nbsp;
you said that we usually use 0/40. There are gaps between us: D
what do you say? Shall we examine it? & nbsp; & nbsp; It has been around 2500km.
08.05.2020 16:09 # 9
The reset event is very easy.
hold down the mileage reset button then turn off the ignition and open key icon with the other hand.
08.05.2020 16:09 # 10
efsanemurat
hold down the mileage reset button at the same time, turn the contact halfway from 10 countdown starts, when the zero is zero, the maintenance indicator becomes 14800
08.05.2020 16:09 # 11
tilbe307
15-40 oil was a little different indeed. & Nbsp; We put 5-30 lpg mobile oil on my vehicle with the advice of my master.
08.05.2020 16:09 # 12
the master has done the right thing, thinned the oil and kept it:))
