Engine oil recommendations
08.05.2020 21:13 # 1
Turgut58
Can I get your engine oil recommendations for a 308 vti gasoline vehicle, friends?
08.05.2020 21:13 # 2
pusutr
Total or mobile1 5w30.
I have been using it for 8 years. I had no problems.
08.05.2020 21:13 # 3
Turgut58
thank you thank you
08.05.2020 21:13 # 4
Total - mobile - is enough, teacher.
08.05.2020 21:13 # 5
AtillaOZEL
Hello. I just talked to the master. The oil change time in my vehicle has arrived. I don't know what oil I am using right now, but this time, let's put castrol 5w40. If there is a user, how is it a problem? My vehicle is 308 Vti Automatic.
08.05.2020 21:13 # 6
Turgut58
thank you. I will buy soner bey filter set, bosch brand is good or not, do you have any information about it
08.05.2020 21:13 # 7
[QUOTE = atillaözel] Hello. I just talked to the master. The oil change time in my vehicle has arrived. I don't know what oil I am using right now, but this time, let's put castrol 5w40. If there is a user, how is it a problem? My vehicle is 308 Vti Automatic. [/ QUOTE]
My 5w40 castrol semi-centric coach use absolutely synthetic oil for our vehicles. castrol minus no quality, unfortunately, if you are going to use oil factory oil or you will turn to other brands. In addition, there may be a lot of oil loss in transition to different oil brands or viscosity. 5000 km up to 1 lt. This will gradually decrease in other treatments. 10000 km 1 liter oil reduction is normal. My advice.
1-total 5w30 is original factory oil.
2- mobile 5w / 30
3-motul fe 5w / 30 (slightly expensive. 20-30 tl)
08.05.2020 21:13 # 8
[QUOTE = Turgut58] thank you. Soner filter set i will buy bosch brand is not good or do you have information about it [/ QUOTE]
Bosh brand is good teacher and produces OEM parts to many companies.
08.05.2020 21:13 # 9
AtillaOZEL
[QUOTE = sonerkyl] [QUOTE = atillaözel] Hello. I just talked to the master. The oil change time in my vehicle has arrived. I don't know what oil I am using right now, but this time, let's put castrol 5w40. If there is a user, how is it a problem? My vehicle is 308 Vti Automatic. [/ QUOTE]
2- mobile 5w / 30
Thank you so much for your advice and help, Soner. I will look at the brands you say. I was amazed by the "Fully Synthetic" text on Castrol Edge.
