engine oil problem
08.05.2020 16:52 # 1
serommm
Hello friends.
My 306 car has a problem of oil reduction. 1 km or even more oil is consumed in 1000 km. I use 10-40 oil in my car. >
I showed it to the master in the late nights, the smoke coming out of the exhaust is normal, blue smoke does not come out. / div>
He said it is not normal to reduce this much, but it seems that everything seems normal.
Previously, my car was missing oil from the top cover gasket. After a while, the temperature gauge was showing 95i, I immediately pulled over and waited for it to fall without stopping the engine, and my guess was that after that day the oil leak started again.
should i have? Some people said to me, use the motor oil boron oil additive product will be corrected, but there are damages so I do not look very warm. I would be very happy if friends who know and come to the press help. If I have LPG, I would appreciate how much oil consumption is written. Thanks in advance.
serommm 2012-06-20 21:20:00
08.05.2020 16:52 # 2
berk2309
This boron does not fall out of the engine does not fall, smoke or normal is normal, if there is a fall in the jacket, there is a mixture of oil in the back part of the engine you do not see, and you have a lot of oil mixture in the back part of the engine & nbsp;
08.05.2020 16:52 # 3
vbmaster
teacher how many lt has gone so far?
08.05.2020 16:52 # 4
serommm
No teacher, there is no fall, but there is no beautiful drowning. There is an antifreeze in the engine. Its color is normal.
Meanwhile, the vehicle is at 138000. A tube was installed at 100000.
08.05.2020 16:52 # 5
berk2309
Look at the back of the engine, look at the back of the engine, where the oil filter can be taken care of.
08.05.2020 16:52 # 6
serommm
I do not understand, my teacher did not drop it on the ground, though it does not appear on the floor, it does not appear, it has complete protection sheet under it, it has normal oil stains on it, but when the master looks at it, he did not drop it. I also look at the opel and toyota forums, they say it is normal for lpg cars to burn at this value, but I think it is not normal. Frankly, I am not afraid that something will happen if I get on this way. Obviously.
08.05.2020 16:52 # 7
berk2309
teacher, look at the back of the engine, I think you do not burn because it is not burning and there is no oil in the water.
