ENGINE OIL PRICE WAS VERY ATTRACTIVE
08.05.2020 18:38 # 1
anlersan
friends, I will change the oil and filters of my car, I asked the price for two places, they gave 120 - 170 pounds. I decided to buy and replace the oil and filters myself. Now on n11.com, 57 lira mobil super 2000 10w-40 how did i find the price? the alıyımm
08.05.2020 18:38 # 2
Serkan
If your car is diesel, it is more suitable in the link below
If it is gasoline, you can also get it from the link below.
Serkan 2014-06-21 10:46:15
08.05.2020 18:38 # 3
anlersan
thank you so much.
08.05.2020 18:38 # 4
madblueblacksea
I think your vehicle has a hdi engine. ? If you read the explanation, it says for the old model engines and how healthy it is to get it from the internet. If the oil filter (15) that gives you 120 lira is given for Castrol edge 10-40 (90) it is quite normal. In case of oil, it is necessary to look for the appropriate seller, not cheap
08.05.2020 18:38 # 5
madblueblacksea
The products sold under the market did not interest me at all. Not because it is the wisdom of the price, but because it is the malady of cheap
08.05.2020 18:38 # 6
Serkan
It is not under the market, its price is its normal price, but they want prices above the market around us, it says the engines that do not have a particle filter called the old type engine, there is no particle filter in 206 HDI, in my choice, there will be catrol edge 5/40 full synthetic oil but no problem in the oil in the link can not remove.
08.05.2020 18:38 # 7
anlersan
Come on 1.4 x-design would be a problem for us?
08.05.2020 18:38 # 8
Serkan
HDI is not the model name Sir, the name of the diesel engine, is your vehicle diesel or gasoline? The oil you mentioned does not harm your vehicle.
08.05.2020 18:38 # 9
ahmed206
Since it is not written, it is probably gasoline :)
I am also approaching the maintenance, again I did not know what to do if I received 10000 maintenance kits I am open to suggestions.
08.05.2020 18:38 # 10
madblueblacksea
[QUOTE = Serkan] It is not under the market, its price is the normal price, but they want prices above the market around us, it says the engines that do not have a particle filter called the old type engine, 206 HDI has no particle filter, my preference is catrol edge 5/40 full synthetic oil but it does not cause any problems in the link. [/ QUOTE]
It is far below the market, but what market you're looking at is important. Your vehicle is HDI if it is diesel and someone has not changed its engine. This is the new model common rail system. You can search the detailed information I am writing on the phone right now. But I can tell you that that oil is not forcing you
08.05.2020 18:38 # 11
samet206
It is a nice product that you can use in elf sport motor oil. It has a price of 4LT 49 TL. It plays less than a half. According to the diesel or if there are different differences. whether you lift the vehicle makes your job easier, in this regard, if you have such an opportunity, you can handle it in a simple way. Finally, if you buy 50 TL oil for the prices you get from 120 to 170 TL, each filter will be 95 TL for 25 TL and 25 TL for each. I think this is not worth seeing :)
08.05.2020 18:38 # 12
pierson
Friends will have a question
I want to change the long road and the oil of the car or something ... the master castrol in the industry was putting 10 40 oil ... the car petrol 2002 model automatic gear ... Is this oil the best for Peugeot 206? Also, if you buy castrol oil 65 TL on the internet sites and 90 TL on the market and industry, will they put oil on the net ... thank you
08.05.2020 18:38 # 13
tongucuk
I heard that castrol has counterfeits on the market.
08.05.2020 18:38 # 14
pierson
Not all from the market here or in similar places .. Castrol uses 10 40 ml Peugeot 206 users
08.05.2020 18:38 # 15
madblueblacksea
You will not know what date of manufacture or what the oil you will buy from Hepsiburada or similar sites. Hepsibu never even sees that oil here. It sends your information to the vendor and the firm is handling the oil to you. you can compare the engine oil to your shoes. If you take the name, it damages your feet, smells, makes mushrooms, burns in hot, freezes in cold, makes sounds in concrete, etc. etc. I have never understood the people who take the risk in terms of engine maintenance to make a profit of 3 5 lira. the savings you get from filters and oils maximum 50 tl. !!! Is it worth taking risks? I recommend that you put an oil you know from somewhere you know. 65 tl put the oil into the engine to 10 tl. 75 tl. When comparing, pay attention to the derivatives of the oils. there is a considerable price difference between mineral oil-semi-synthetic-fully synthetic oils
08.05.2020 18:38 # 16
princealtair
I want to change oil + filter, I found the presentation, how about the set in the link
http://www.peugeotmarket.com/peugeot-206-14-benzınlı-1999-2003-fıltre-setı-orjınal,pr-818.html
08.05.2020 18:38 # 17
ahmed206
[QUOTE = pierson] Not all from the market, here or in similar places .. Castrol 10 uses 40 ml Peugeot 206 users [/ QUOTE]
So far, I used Total 10-40 which Pejon suggested, this time I used Castrol Magnatec 10 - 40.
