engine oil pressure error
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 301
08.05.2020 21:22 # 1
tahagor
Hello, I get this warning when I run the tool. When the second comes and goes. It doesn't always do. I was able to shoot a video and take a picture to see the error ( https://i.hizliresim.com/bvXoQd.jpg ). I checked the oil level, there is no problem.
The incoming alert does not appear in the alert history.
08.05.2020 21:22 # 2
Pejocu Adam
hi aleykum hello I became a new member to this group, I saw it in my 206+ vehicle, I had given this warning when the oil change time came, or it was a problem caused by the customer during the new oil change, maybe it might have come to the client, show it to a master or see for yourself, it also gives warning when idling.
08.05.2020 21:22 # 3
tahagor
As in the video, it comes and goes instantly, it does not remain as an error. It seems to me that there may be a problem with the pressure transmitter, something that clogs the tip of the transmitter while it stops as you say may be able to transmit the pressure when the system is unable to withstand pressure and there may be no malfunction?
[TUBE] ı_uvtv3qjxc [/ TUBE]
03.06.2020 14:35 # 4
ziyacakmak
Hello, I see the same problem with my 207 1.4 HDI vehicle. I have a question for you. Can I learn how you solved this problem. Have a nice day.
04.06.2020 06:01 # 5
uivgen
How many thousand km and how many months have it been since the oil change? The oil may have lost its properties if it has been a long time. In this case, you will start to receive this warning more often while idling, and when you release gas, the warning disappears because it starts to lubricate. It is useful to go to the industry as soon as possible. When you stand at the lights or something, be careful to keep it at 2000 cycles. May cause bigger problems uivgen2020-06-04 06:02:22
04.06.2020 10:07 # 6
ziyacakmak
Hello, it has been 7000 km since the oil change. Normally, there is no oil leakage, oil burning, blue or black smoke in the vehicle, but the level indicated by the dipstick is always the same since the last maintenance, but it seems that there is too much oil above the marked part of the dipstick.
04.06.2020 11:46 # 7
ismailkaya
What is the engine type of your vehicle. Is there LPG
04.06.2020 12:00 # 8
ziyacakmak
I mentioned above 2012 HDI 1.4 euro5 engine diesel
04.06.2020 13:42 # 9
uivgen
It is important in the period up to km. There are oil quality, climatic conditions, etc., of course. Check your oil. Has it started to turn gray? Likely to be caused by oil filter
04.06.2020 14:01 # 10
ziyacakmak
Exactly, in the first place, the sender and the oil filter changed, it did not fail that day, but the next morning I got the same error. Pump replacement is currently being tried. The climate condition is ultimately a vehicle in the Mediterranean climate and has not been exposed to extreme cold conditions. kmsi is also around 127 thousand. In terms of oil quality, castrol 5 30 had a good version, put in maintenance, it was already 7 thousand km, maintenance done. Let's see what will come out.
04.06.2020 23:32 # 11
ismailkaya
Check the pressure hoses with the turbo hoses for clogging.
