Engine oil maintenance top quality engine oil
08.05.2020 19:34 # 1
06AV1465
My friends car 2006 model 307 1.6 hdi 113bin I will change the engine oil in Izmir I live in Izmir which is the best quality and healthiest engine oil.
08.05.2020 19:34 # 2
oguzhan53
Casrol edge 5W-40 is the best quality and compatible oil you can get in your vehicle. oguzhan53 2015-12-30 15:07:50
08.05.2020 19:34 # 3
usta42
My brother is the brand for the car under the best oil hood and the oil of value is the peugeot original oil total brand of course there is also some national brand event in the job because the total oil company proposes a peugeot shell for french fitting
08.05.2020 19:34 # 4
my teacher fat mobile and castrol
08.05.2020 19:34 # 5
Sercan Mungan
You can buy the right one from Mobil 1 or Castrol edge fully synthetic oils.
08.05.2020 19:34 # 6
palet
Peugeot recommends the use of 5/30 and 5/40 oil. 5/30 full synthetic and 5/40 semi-synthetic. Gaziemir, which is the most affordable in Izmir in 5/30 full synthetic oils, is Lukoil (black box) oil sold in the subway. It is used without any problems in vehicles even at -30 degrees in the cold of Siberia. If you search on YouTube as lukoil 5 30, you can see simple fluidity tests at -30 degrees.
08.05.2020 19:34 # 7
oguzhan53
5w-40 is fully synthetic. Let's not give false information.
08.05.2020 19:34 # 8
06AV1465
In general, castrol edge is recommended, so I live in yesilova, who knows where I can get this oil best, and I know that as a region
08.05.2020 19:34 # 9
vpro
I think there is no difference unless the oil brand is the supplier industry.
Bidet will be okay, of course.
08.05.2020 19:34 # 10
oguzhan53
I buy castrol edge 5w-40 online but it is also available in industries. In building markets, it is sold for 30-40 TL more. oguzhan53 2015-12-31 00:44:09
08.05.2020 19:34 # 11
06AV1465
They said they even changed the engine sound so did you notice anything?
08.05.2020 19:34 # 12
The teacher changes the sound of the engine every time you change the oil.
08.05.2020 19:34 # 13
palet
[QUOTE = oguzhan53] 5w-40 is fully synthetic. Let's not give false information. [/ QUOTE]
You are right. I gave incorrect information about 5W40.
08.05.2020 19:34 # 14
sagos
My friend has used many different types and types of oil for 24 years, and I have used many types of oil from oil office brand oil to castrole. I think it is superior to other oils in terms of protecting engine compression as well as keeping silent after oil change.
08.05.2020 19:34 # 15
06AV1465
Thank you, sagos suggestions that I will consider
